查看: 74|回复: 5
Good Smoke “Big Easy Cognac” Cigar
 楼主| 发表于 2019-7-22 08:24:26 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1920.0,\"name\":\"\",\"url\":\"\",\"width\":1440.0}]","canComment":true}
发表于 2019-7-23 02:02:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"This is probably one of the best photographs on trucker path, you used a good depth of field, rule of nines were applied, and you actually have the subject in focus which is the cigar and you are in the background giving context. Some lines are coming out of your head, the reflection in the glasses is distracting, and your hand is chopped off but it’s miles ahead of any picture I’ve seen on this site. ","replyToPid":0}
发表于 2019-7-22 09:54:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dont inhale. Lol","replyToPid":0}
发表于 2019-7-22 08:55:41 来自手机 | 显示全部楼层
 楼主| 发表于 2019-7-30 20:36:52 来自手机 | 显示全部楼层
631176 发表于 2019-07-22 18:02:54 This is probably one of the best photographs on trucker path, you used a good depth of field, rule of nines were applied, and you actually have the subject in focus which is the cigar and you are in the background giving context. Some lines are coming out of your head, the reflection in the glasses is distracting, and your hand is chopped off but it’s miles ahead of any picture I’ve seen on this site.
","text":"Thank you ","replyToPid":153032}
发表于 2019-10-18 20:08:04 来自手机 | 显示全部楼层
","text":"I don't think photography critic is needed here. This isn't a photography class. it is only a POST. nothing more. not a magazine.","replyToPid":153032}
GMT+8, 2026-2-12 21:18 , Processed in 0.107805 second(s), 24 queries .
