查看: 136|回复: 6
WT?
 楼主| 发表于 2019-7-21 21:26:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"A/C goes out in AZ on I 15S. It was 88° at night. Pushed through to Vegas to TA and was informed  it wouldn't be till 8am when the tech comes in with 5 trucks before me. H to the naw!!! Get back in the truck with intentions of pushing through to Barstow TA and lo and behold, the air is working🤔 I have a gremlin that didn't ask before he got on the truck 😅","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-21 22:24:56 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"could be a bad temperature sensor, you can experience intermittent failure before it permenantly goes out, I would still get it fixed. it will stop working again.\n\ncould be a lot of things, but do get it checked."}
 楼主| 发表于 2019-7-21 22:40:06 来自手机 | 显示全部楼层
462372 发表于 2019-07-21 14:24:56 could be a bad temperature sensor, you can experience intermittent failure before it permenantly goes out, I would still get it fixed. it will stop working again.\n\ncould be a lot of things, but do get it checked.
","text":"Yep. Only 29K on the dash. Shouldn't be happening at all.","replyToPid":151997}
发表于 2019-7-21 23:45:08 来自手机 | 显示全部楼层
","text":"yup. matter of time. prolly air in the system.","replyToPid":151997}
发表于 2019-7-22 22:15:41 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"easy fix. it's the ac gas getting too warm. turn off truck and pour some water on little radiator in front of main radiator. it will cool it down, then when you start back up it will work again. happens all the time to mine cause it runs all the time in hot weather."}
发表于 2019-7-22 22:15:47 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Just had the same problem till it went completely out.Ended up being the temp sensor "}
发表于 2019-7-23 01:26:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yay intermittent problems! 😞","replyToPid":0}
GMT+8, 2026-2-5 07:49 , Processed in 0.070152 second(s), 24 queries .
