查看: 141|回复: 4
2017 kw T680 parking brake
 楼主| 发表于 2019-7-21 20:07:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"Sometimes when I'm heavy, 70 and up and park on a hill after I set the parking brake the truck will keep wanting to roll down the hill so I set the trailer brakes too. Should I get my parking brake looked at or just keep it moving since setting the trailer brakes does the trick. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-21 21:04:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"What kind of brakes, drum or disc?. First of all it's best to set the trailer brakes anyway but it still sounds like the tractor brakes may be a little out of adjustment. Try this- park on level ground, chock the wheels, and release your brakes. Run the engine till the air pressure reaches 100 - 110 lbs, and shut the truck off. Release the brakes and pump the brake pedal until all the air pressure is out of the tanks and the brakes set themself. A lot of times that will adjust the brakes, but like I said it's always best to set the trailer brakes too.","replyToPid":0}
发表于 2019-7-21 23:30:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Considering it's a new truck it should be equipped with self adjusting brakes. Yes pumping the brakes or reversing and a good hard brake should work. But if they are too far out of adjustment will will need to adjustment with a wrench. Anytime you park on a good grade with that much load its recommended you also set the trailer brakes.","replyToPid":0}
发表于 2019-7-22 00:05:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do a DVIR how set your trailer brakes release the tractor brake crawl underneath the truck and pull on the slack adjusters if it moves it needs to be adjusted ","replyToPid":0}
发表于 2019-7-22 09:41:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Why would you NOT set your trailer brakes all the time (except maybe winter so don’t freeze)?\n","replyToPid":0}
GMT+8, 2026-2-5 06:15 , Processed in 0.100433 second(s), 24 queries .
