查看: 299|回复: 17
Need some help here!
 楼主| 发表于 2019-7-21 03:45:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does it feel like your legs start going numb after driving a few hours? My thighs and calf’s start to ache. I was wondering if this is normal and if a seat cushion would help. I see the purple seat cushion at the the stops and was wondering is this normal or do I need to see a doctor for circulation issues lol","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-21 05:23:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take your wallet out of your back pocket.","replyToPid":0}
发表于 2019-7-21 06:17:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"“Homans sign” is what they would look for at a medical clinic, dorsiflex your feet (point your toes up as hard as you can) if you feel an excruciating sharp pinpoint pain you just might have a blood clot and they will run further tests.","replyToPid":0}
发表于 2019-7-21 05:07:49 来自手机 | 显示全部楼层
534465 发表于 2019-07-20 19:50:26 my advice is you should see a docter. my friend had same problem.
","text":"what was their conclusion?","replyToPid":151552}
发表于 2019-7-21 05:09:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"seat adjustments. not to high in the front, but the stock seat on these things are terrible.","replyToPid":0}
发表于 2019-7-21 03:50:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"my advice is you should see a docter. my friend had same problem.","replyToPid":0}
发表于 2019-7-21 05:42:03 来自手机 | 显示全部楼层
发表于 2019-7-21 06:15:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sitting for extended periods of time puts you at extreme risk for deep vein thrombosis. Take a baby aspirin before your shift, only if you have no pre existing cardiovascular conditions. \n","replyToPid":0}
发表于 2019-7-21 06:41:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Personally I fidget in the seat I have adhd. This helps to prevent dvt. Also take a break every 2 hours and stand and walk around. Drink water not sugary drinks, when driving. And try to get in some exercise in the off duty time. Seat adjustment is crucial also. Don’t leave it all the way down. Sit up straight and raise the back of the seat if possible so it’s not acting like a bucket seat. You could be experiencing the beginnings of blood clots in your legs. Which is super bad. Ever hear of a driver being found dead in the cab. A lot of time this is what causes it. Deep vein thrombosis or dvt, a blood clot from the legs which blocks the heart or lungs up and kills. ","replyToPid":0}
发表于 2019-7-21 06:43:13 来自手机 | 显示全部楼层
696362 发表于 2019-07-20 22:41:05 Personally I fidget in the seat I have adhd. This helps to prevent dvt. Also take a break every 2 hours and stand and walk around. Drink water not sugary drinks, when driving. And try to get in some exercise in the off duty time. Seat adjustment is crucial also. Don’t leave it all the way down. Sit up straight and raise the back of the seat if possible so it’s not acting like a bucket seat. You could be experiencing the beginnings of blood clots in your legs. Which is super bad. Ever hear of a driver being found dead in the cab. A lot of time this is what causes it. Deep vein thrombosis or dvt, a blood clot from the legs which blocks the heart or lungs up and kills.
","text":"It’s also often not diagnosed in time or diagnosed as something else incorrectly much of the time. It can be remedied but if not in time may cost your life. Take any sign seriously and seek medical reference from a physician be sure to notify him that you are a truck driver and at very high risk of dvt because of that. ","replyToPid":151648}
GMT+8, 2026-4-18 10:47 , Processed in 0.081210 second(s), 24 queries .
