查看: 243|回复: 8
Personal Conveyance?
 楼主| 发表于 2019-7-21 03:01:11 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can you unload under this status?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-21 07:01:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"u can do whatever you want it's not illegal till u get caught","replyToPid":0}
发表于 2019-7-21 06:04:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"If I am not mistaken, we are not allowed to use it at any time if we have a load on us. I don’t know if there are exceptions for such a rule. ","replyToPid":0}
发表于 2019-7-21 06:19:24 来自手机 | 显示全部楼层
发表于 2019-7-21 06:18:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"No you cannot. Your still under load","replyToPid":0}
发表于 2019-7-21 08:13:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Can’t do anything that’s considered “furthering” the load. \nI would go to sleeper birth once unloaded use your pc to find nearest truck stop. Make sure you don’t stop at a near by company yard like I did using pc. ","replyToPid":0}
发表于 2019-7-21 08:26:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope ","replyToPid":0}
发表于 2019-7-22 10:21:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"Listen. If your at a shipper and run out of time your not on the clock, when you leave you use pc to find parking. Same applies to consignees. This how you use it if your a company driver. You cannot use it to set yourself better for a pu or delivery. It's different for OO I believe.","replyToPid":0}
发表于 2019-9-14 00:56:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I used PC to get from a full truck stop to my company yard in the same city. basically, PC is only for going home your truck, not under a load, and to find parking if you're out of dot time. not allowed to do anything official under that status.  hell of a ticket.","replyToPid":0}
GMT+8, 2026-4-18 07:12 , Processed in 0.080300 second(s), 24 queries .
