查看: 639|回复: 6
newbie question
 楼主| 发表于 2019-7-20 11:56:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"does running apu drain the truck batteries ? I'm going to have to stop for 18 hours so I'd like to know if itll be alright to run the apu for that long. I'm not too sure how apu works. its tripac and the truck is 19 cascadia. thanks !","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-28 02:08:43 来自手机 | 显示全部楼层
617698 发表于 2019-07-20 12:37:46 It only drains your batteries if the APU belt has been installed incorrectly (as mine was).
","text":"oh? maybe that's my issue.   but now it just won't even try to start    i get the yellow triangle!  is all now ","replyToPid":151382}
回复 支持 0 反对 4
 楼主| 发表于 2019-7-20 12:33:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"meant to upvote your post. sorry! but thank you !","replyToPid":0}
回复 支持 1 反对 3
发表于 2019-7-20 20:37:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"It only drains your batteries if the APU belt has been installed incorrectly (as mine was). ","replyToPid":0}
回复 支持 0 反对 3
发表于 2019-12-20 23:14:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"the purpose is to keep you comfy while charging the batteries","replyToPid":0}
发表于 2019-9-6 07:20:53 来自手机 | 显示全部楼层
686429 发表于 2019-07-27 18:08:43 oh? maybe that's my issue.   but now it just won't even try to start    i get the yellow triangle!  is all now
","text":"nope none of that.  a bad alternator blew the fuse.  ","replyToPid":157681}
发表于 2019-10-10 19:37:03 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"..."}
GMT+8, 2026-4-17 06:24 , Processed in 0.105531 second(s), 24 queries .
