查看: 267|回复: 8
Idle in California
 楼主| 发表于 2019-7-20 11:12:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Do officers really give tickets for idling in Cali?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-20 21:40:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Almost all newer trucks are California idle certified. Which means you can idle in California. ","replyToPid":0}
发表于 2019-7-20 11:20:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"only if you get caught. lol... I idle all the time there, never had an issue.","replyToPid":0}
发表于 2019-7-21 12:23:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I live and do 95% of my trucking in the central coast of Cali and never have seen or worried about citations for idling. If it happens it’s definitely an outlier ","replyToPid":0}
发表于 2019-7-20 11:24:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"they idle all the time, I use my rig master, but if it's not working, I idle  no one has ever bothered me, and the idea law only is in effect up until a certain temperature, same with cold temperatures","replyToPid":0}
 楼主| 发表于 2019-7-20 20:17:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not sure what the temperatures are but the truck won’t idle below 70 degrees. Actually it was very nice last night so I didn’t idle but usually it’s so hot! Probably because I’m more north than usual. Thank you guys!","replyToPid":0}
 楼主| 发表于 2019-7-21 03:42:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you! I forgot about that sticker on the side! My sister in law brought it up because she’s an environmentalist but now I know what that sticker means lol","replyToPid":0}
发表于 2019-7-21 12:13:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"the anti-idle laws typically don't apply to trucks Certified Clean Idle (those that take def).\n\nI've idled often in CA and never been bothered.  Even watched as people patrolling the lot made old trucks shut down."}
发表于 2019-7-22 10:45:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Think twice in some areas around san fran. Sticklers","replyToPid":0}
GMT+8, 2026-4-18 10:41 , Processed in 0.088266 second(s), 24 queries .
