查看: 147|回复: 6
Aside from running a Dyno
 楼主| 发表于 2019-7-20 03:47:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"What else do you do when buying second-hand trucks? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-20 08:39:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"oil sample if they haven't changed the oil yet.","replyToPid":0}
发表于 2019-7-20 06:43:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"ur home work \ninspect it like an annual inspection","replyToPid":0}
发表于 2019-7-20 08:56:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oil analysts ","replyToPid":0}
发表于 2019-7-20 22:54:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy a 99 or older or glider kit save $20 k back for an overhaul. If a glider has more than 600k miles it will need to be rebuilt by 750k. Almost every used truck claims to have an overhaul.","replyToPid":0}
发表于 2019-7-22 10:53:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Run an algaecide through the fuel system or add an atomizer in the fuel rail system. Flip it lol and check every inch of the frame and suspension. New batteries and alt dont wait brand new tennis shies 3000+ inverter with a breaker box and inline fuse. Just depends what you know about what your buying. Homework homework dont leave yourself at the mercy of desperation because you wint any there","replyToPid":0}
发表于 2019-7-22 21:58:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Everything you need to know is on Rawze.com. They even have a checklist for you to take.","replyToPid":0}
GMT+8, 2026-4-17 20:19 , Processed in 0.096508 second(s), 25 queries .
