查看: 645|回复: 24
Bob tail
 楼主| 发表于 2019-7-19 08:55:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi, everyone.\n Quick question, I’ve now bob tail . So , should I Enter to weigh stations? 🤔🤔🤔","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-19 11:31:19 来自手机 | 显示全部楼层
回复 支持 6 反对 1
发表于 2019-7-19 09:02:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you are told to do so then yes.  um...","replyToPid":0}
回复 支持 4 反对 1
发表于 2019-7-19 20:05:29 来自手机 | 显示全部楼层
731453 发表于 2019-07-19 05:04:51 Here’s an answer for all you rookies, about interning a weigh station. When in doubt enter the scale with out question. When traveling on any toad way read posted signs. If you can’t read English run the scales and find out what happens. Good luck and be safe.✌🏻
","text":"If you cant read english lol, check your spelling dude.","replyToPid":150625}
发表于 2019-7-19 13:04:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Here’s an answer for all you rookies, about interning a weigh station. When in doubt enter the scale with out question. When traveling on any toad way read posted signs. If you can’t read English run the scales and find out what happens. Good luck and be safe.✌🏻","replyToPid":0}
发表于 2019-7-19 11:50:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I stop 🛑... most of the time...","replyToPid":0}
发表于 2019-7-19 11:16:39 来自手机 | 显示全部楼层
558928 发表于 2019-07-19 01:02:51 if you are told to do so then yes.  um...
","text":"yes","replyToPid":150466}
发表于 2019-7-19 12:16:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes","replyToPid":0}
 楼主| 发表于 2019-7-22 10:53:44 来自手机 | 显示全部楼层
612134 发表于 2019-07-19 04:38:45 inspections are not just on your trailer. it is on your tractor and or on the trailer. you can still get f*cked even if you do not have a trailer haha
","text":"That day was the lucky day, thank you)","replyToPid":150603}
发表于 2019-7-19 12:39:02 来自手机 | 显示全部楼层
662769 发表于 2019-07-19 03:31:19 Absolutely not just hammer down and keep on truckin
","text":"Agreed!","replyToPid":150562}
发表于 2019-7-19 12:40:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Of course, sweet heart.. Unless you got a pre pass device","replyToPid":0}
发表于 2019-7-19 12:23:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes you are still a commercial vehicle plated gvw 80,000. Follow preparation if equiped","replyToPid":0}
发表于 2019-7-19 12:23:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes you are still plated for 80,000. ","replyToPid":0}
发表于 2019-7-19 12:38:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"inspections are not just on your trailer. it is on your tractor and or on the trailer. you can still get f*cked even if you do not have a trailer haha","replyToPid":0}
GMT+8, 2026-4-18 12:29 , Processed in 0.115425 second(s), 24 queries .
