查看: 692|回复: 13
MPG MILESTONE!!
 楼主| 发表于 2019-7-18 23:43:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Just want to let people know that the new freightliners are capable of 10MPG!\nI bought an automatic 2019 evolution P4 with DD13. This is a PRIME INC SPECCED TRUCK, so I don’t know all the details of the setup, but PRIME did their homework.\nI pull refer trailers with all kind of weights. Meat and beer loads are maxed out at 79,000lbs. I drive all 48 states. I also am a CDL trainer, so I have rookies driving my truck. We use cruise control 70%+ of the time and drive between 55-57mph.\n\nAll that said here are the numbers\nBought new truck with 323 miles on the odometer on January 15, 2019.\n89405 miles .... 9921 gallons used...\n\n9.011 MPG!!!\n\n\n\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1206.0,\"name\":\"\",\"url\":\"\",\"width\":678.0}]","canComment":true}
发表于 2019-7-19 06:35:07 来自手机 | 显示全部楼层
回复 支持 4 反对 2
发表于 2019-7-19 11:52:36 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I can only really speak for my KW, but I feel like any 2016+ truck can get the same mpg at 55-57mph\n\nCongrats though, I’m glad you’re happy with it😁"}
 楼主| 发表于 2019-7-19 05:14:16 来自手机 | 显示全部楼层
670977 发表于 2019-07-18 20:29:25 Do you idle or it has an APU
","text":"It has an APU which has 800 hours . Average 4.5 hours per day. Uses the diesel from the tanks, so I guess and am getting better than 9.0.\nThe CPU says idle time is .58% of total engine hours. I turn off the engine ASAP every time I stop\n","replyToPid":150255}
 楼主| 发表于 2019-8-4 04:47:03 来自手机 | 显示全部楼层
750595 发表于 2019-08-02 09:28:56 you get alot better than I do I have 2019 cascadia with DD15 had since 737 miles got 116 thousand on it now... travel NY all the way to CA only problem I've had is radiator cracked in NMexico. Warranty covered it. But I average 7.9 mpg on a side note.... what company you get grill guard from ?
","text":"The blacked out grill was add on from factory. Prime inc installed the deer guard for $600","replyToPid":165702}
发表于 2019-7-19 04:29:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do you idle or it has an APU","replyToPid":0}
发表于 2019-7-19 04:32:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take less fuel and sale less fuel and price go up on fuel ps nice truck","replyToPid":0}
发表于 2019-7-19 04:34:04 来自手机 | 显示全部楼层
709200 发表于 2019-07-18 20:32:30 Take less fuel and sale less fuel and price go up on fuel ps nice truck
","text":"Verry nice like the painr","replyToPid":150256}
发表于 2019-7-19 05:56:20 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"what's the gross in 89k and 55mph"}
发表于 2019-7-19 06:30:15 来自手机 | 显示全部楼层
617350 发表于 2019-07-18 21:14:16 It has an APU which has 800 hours . Average 4.5 hours per day. Uses the diesel from the tanks, so I guess and am getting better than 9.0.\nThe CPU says idle time is .58% of total engine hours. I turn off the engine ASAP every time I stop\n
","text":"Thank you very much for sharing all this infos. ","replyToPid":150291}
 楼主| 发表于 2019-7-19 09:19:06 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"$151,999.20 gross to the truck since purchasing. 01/15/2019. 26 weeks. $5846/week average. Includes off time"}
GMT+8, 2026-2-4 20:08 , Processed in 0.075882 second(s), 24 queries .
