查看: 211|回复: 20
Do not buy DEF at the pilot in Breaux Bridge,LA
 楼主| 发表于 2019-7-18 09:25:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"96 degrees can't run the truck to keep cool. How Much am I getting paid again?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":980.0},{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":980.0}]","canComment":true}
发表于 2019-7-18 09:45:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drain it out.... and put in some new DEF","replyToPid":0}
发表于 2019-7-18 10:13:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"The KW gives you plenty of warning that you are low on def. You shouldn't run below 1/4. Going that low you may have to get a part replaced. From that point on, I dont run below 1/2 . Good luck.","replyToPid":0}
发表于 2019-7-18 13:07:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"unhook the lines at the tank and the lines going out to filters and drain the tank and blow the lines out hook em back up dump a couple of gallons in and cross your fingers. hopefully it didnt clog injector up and filters.","replyToPid":0}
发表于 2019-7-18 11:11:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just can’t believe it says limp home mode wtf.....","replyToPid":0}
发表于 2019-7-18 09:39:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Seriously?","replyToPid":0}
发表于 2019-7-20 05:21:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"hell if thats a company truck i hope they paid for the hotel","replyToPid":0}
发表于 2019-7-18 12:30:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks... chaotic 😆","replyToPid":0}
发表于 2019-7-18 11:12:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"That’s not the fluid issue. You probably clogged up the filter by running it so low. ","replyToPid":0}
发表于 2019-7-18 10:26:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"The last time I was critically low, I had to grab 1 gallon from Walmart before I got to a truck stop","replyToPid":0}
发表于 2019-7-18 11:11:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just can’t believe it says limp home mode.......","replyToPid":0}
GMT+8, 2026-2-4 12:37 , Processed in 0.061566 second(s), 24 queries .
