查看: 183|回复: 6
Truck life
 楼主| 发表于 2019-7-18 04:35:13 来自手机 | 显示全部楼层 |阅读模式
{"text":"Any recommendations for backing up? I’m new and I’m just learning ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-18 06:04:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"95% of a successful backing maneuver is in the set up. Watch other drivers and how they approach the move you're preparing to make, if you have the opportunity. I guarantee you'll see the right - and wrong- way if you watch long enough. Also if you're having to jack your trailer into a tight space be sure to watch for low obstacles on your passenger side that you may hit when the tractor swings around to \"get under\" the trailer. Often times a driver gets so involved with watching the trailer he forgets about this, and smashes their steps or fuel tank on those pretty little yellow poles that tend to come out of nowhere when you're backing.","replyToPid":0}
发表于 2019-7-18 06:10:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make sure the trailer is pointed in the direction you want to back before you stop moving forward ","replyToPid":0}
发表于 2019-7-18 05:21:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"turn towards the problem. if you see your trailer going a direction you dont want, steer towards it.  Ie your trailer is too far right, turn to the right and the trailer will move the other way.  Turning towards the issue has helped me a lot.","replyToPid":0}
发表于 2023-11-13 04:22:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"You won’t be a certified pilot without training. Likewise, you will have to practice (a lot). \n\nPractice in an empty parking area, always use your 4 flashers, and try to always back driver side…although some receivers will only offer the blind side option.","replyToPid":0}
发表于 2019-7-18 10:01:09 来自手机 | 显示全部楼层
发表于 2023-11-12 09:45:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take your time and remember G. O. A. L. ","replyToPid":0}
GMT+8, 2026-4-16 07:54 , Processed in 0.144154 second(s), 24 queries .
