查看: 641|回复: 29
driving with ELD logged off
 楼主| 发表于 2019-7-18 00:22:45 来自手机 | 显示全部楼层 |阅读模式
{"text":"my company encourages solo drivers to turn off their log book when they are out of hours, and no more scales between their location and destination, or they will give another person's login to get us to keep driving. \n\nis this worth the risk of an extra 1000 miles a week? what's the penalty if I get pulled over doing either of these things?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-18 01:34:54 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Third thing you also need to think about. You are responsible for your actions for 7 years. If your company gets dot audited they look back at 7 years of logs for every driver. With eld it’s much easier to do. \n\nSo once your company gets caught (it will happen just a matter of when). You can still be fined given csa points and lose your cdl. Even if you don’t drive anymore or work for another company. "}
回复 支持 7 反对 1
发表于 2019-7-18 01:32:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s not about scale you have to cross. If you get into an accident you will get caught. Even if a car hits you they want to see your logs. ","replyToPid":0}
回复 支持 6 反对 1
发表于 2019-7-18 01:31:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you get caught the officer would get a promotion. \n\nFalsify logs, being out of hours. Right there alone is at least 5000 plus mandatory shutdown. \n\nThe laws are getting way more tougher. \n\nProbably more and you would probable lose your cdl. No company would touch you with how many points on your csa score. ","replyToPid":0}
回复 支持 6 反对 1
发表于 2019-7-18 02:28:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"If they are stupid enough to put on Qualcomm take picture of instructions on screen. Bottom line is that it's your license that's at risk, not the companies. That will lie their @$$ of and say they never instructed you to do that.","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-7-18 01:59:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would ask the company to put it in writing in case something happens.","replyToPid":0}
回复 支持 4 反对 2
发表于 2019-7-18 03:00:43 来自手机 | 显示全部楼层
607385 发表于 2019-07-17 18:56:22 kinda depends I got hit by a car last month they careless about my logs
","text":"I was rear ended at a stop light to go into the truck stop about 6 months ago. Cop wanted to see my logs for the last 8 days my bol and everything. Luckily I had like an hour left. ","replyToPid":149335}
发表于 2019-7-18 02:41:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont turn it off. use PC and make sure the truck stop or rest areas are full.","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-7-18 01:37:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If a company tells you to do that contact your company safety department and let them know. If it’s your safety department saying to do that then you need to leave that company ASAP. If you don’t like the company you can easily report it to dot by calling or stopping at any weigh station. "}
发表于 2019-7-18 08:27:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is more to life than money. There is such things called principals and values as a human being. I would not rat someone out or turn in a business for doing illegal things for even a hundred thousand dollars.","replyToPid":0}
发表于 2019-7-18 07:43:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Personal conveyance. When you use the truck for personal use. Another huge no no big fines if you get caught. \n\nHad a friend do that and company caught him because he didn’t start his day where he started pc. Wrote him up next time he will be fired. ","replyToPid":149540}
发表于 2019-7-18 02:56:22 来自手机 | 显示全部楼层
542330 发表于 2019-07-17 17:32:35 It’s not about scale you have to cross. If you get into an accident you will get caught. Even if a car hits you they want to see your logs.
","text":"kinda depends I got hit by a car last month they careless about my logs","replyToPid":149283}
GMT+8, 2026-4-18 12:28 , Processed in 0.066471 second(s), 24 queries .
