查看: 127|回复: 2
Log violations ?
 楼主| 发表于 2019-7-17 22:08:42 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a question please , let’s say “ you pickup a load or unloaded but you didn’t show Some onduty time on your Log cuz you were off-duty so how big problem is that ?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-9-14 01:53:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"when I bump the dock, I go on sleeper berth until I get my green light. otherwise, if you're taking care of company business, you have to be logged as on duty.  some drivers go off driving to on duty as soon as they hit the yard until they actually dock, when they go on sleeper berth, but I'm not sure about the technical legality of it.","replyToPid":0}
发表于 2019-10-11 16:43:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should log it as you do it... ex: your driving and arrive at a customer to load or unload, once stopped, change to on duty not driving, check in with the customer, get your door or dock assignment and return to your truck, once in the door/dock... go to off duty, unless your required to load/unload or count freight (anything you get payed to do) other wise your off duty/unpaid... this is an easy violation for officers to write with elogs cause most drivers aren’t logging on duty time, same goes for fueling... always show fueling as I duty or any other maintenance type items show some on duty time for! Also, make sure you know how to update the shipper and trailer numbers in your elog program, again it’s a form and manner violation, but all dings hurt when it comes to the DOT/FMCSA","replyToPid":0}
GMT+8, 2026-3-21 12:37 , Processed in 0.332723 second(s), 23 queries .
