查看: 256|回复: 9
What did I do wrong?
 楼主| 发表于 2019-7-17 10:21:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi!  I’m the navigator in our 45’ Motorhome with car in tow as my husband drives and I signed up making sure all roads conducive to our height and length.  What did I do wrong?  I put in my destination but don’t see how to start the direction guidance.  I followed the path manually but that won’t work.  Any suggestions?  By the way the I-70 is horrible to drive on with all the bumps. Or is it us??  Thank you. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-17 11:27:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"I70 is not the only crappy road by the way. wait till you enjoy the fine roads of Indiana","replyToPid":0}
发表于 2019-7-17 19:57:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"My vote for worst roads is Louisiana. ","replyToPid":0}
发表于 2019-7-17 18:07:13 来自手机 | 显示全部楼层
249029 发表于 2019-07-17 03:27:26 I70 is not the only crappy road by the way. wait till you enjoy the fine roads of Indiana
","text":"Louisiana","replyToPid":148779}
 楼主| 发表于 2019-7-17 21:34:29 来自手机 | 显示全部楼层
","text":"Great tax dollars at work.  We’re here now.  ","replyToPid":148779}
 楼主| 发表于 2019-7-17 21:35:04 来自手机 | 显示全部楼层
249029 发表于 2019-07-17 03:14:25 if you are not going to go premium,  you might as well use Google maps.  i think what you are asking tho, is a feature that was taken away in order to improve the app in a way to make it worse,  if you follow. there should be a circle with arrows middle bottom. enter your address there and then hit route.  it will route it for you with a thick blue line.  also a terrible improvement. hope that's what you are asking. just typing an address in the search bar doesn't work anymore.
","text":"Thank you.  Found the blue line just no voice prompts.  Appreciate your time.   ","replyToPid":148768}
发表于 2019-7-17 11:14:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you are not going to go premium,  you might as well use Google maps.  i think what you are asking tho, is a feature that was taken away in order to improve the app in a way to make it worse,  if you follow. there should be a circle with arrows middle bottom. enter your address there and then hit route.  it will route it for you with a thick blue line.  also a terrible improvement. hope that's what you are asking. just typing an address in the search bar doesn't work anymore.","replyToPid":0}
发表于 2019-7-17 11:02:47 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"What did you do wrong? you didnt but an atlas and plan your trip with it.... Honestly though, you can buy a Garmin dezl and input your dimensions, cost 250 with on a discount, and remember you're going to pay more than that with the Trucker P premium\nEdit: I am sorry that I cannot Inform you the problem you're having with the app, I've never used the Truck Routing feature"}
 楼主| 发表于 2019-7-17 21:32:38 来自手机 | 显示全部楼层
553636 发表于 2019-07-17 03:02:47 What did you do wrong? you didnt but an atlas and plan your trip with it.... Honestly though, you can buy a Garmin dezl and input your dimensions, cost 250 with on a discount, and remember you're going to pay more than that with the Trucker P premium\nEdit: I am sorry that I cannot Inform you the problem you're having with the app, I've never used the Truck Routing feature
","text":"Thank you!!","replyToPid":148765}
发表于 2019-7-18 20:34:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"I 95 sc are bad also","replyToPid":0}
GMT+8, 2026-4-18 10:46 , Processed in 0.064710 second(s), 24 queries .
