查看: 281|回复: 13
Just curious what air pressure everyone runs in their tires during the summer months. Thanks!!
 楼主| 发表于 2019-7-17 01:53:35 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-4-14 19:40:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"105","replyToPid":0}
发表于 2019-7-17 11:13:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Run them at max. Sidewall flex creates heat. I run super singles on my drives and I run them at 120psi, no problems.","replyToPid":0}
发表于 2019-7-17 02:19:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"100 psi","replyToPid":0}
发表于 2019-7-17 03:11:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Max psi , tires have to flex more otherwise resulting in quicker heat ups , ","replyToPid":0}
发表于 2019-7-17 03:18:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"105 in all them","replyToPid":0}
发表于 2019-7-17 04:19:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"When I owned my truck during the summer I’d run at 110. Winter I would lower then back to 100. ","replyToPid":0}
发表于 2019-7-17 08:56:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"110 always 🙅","replyToPid":0}
发表于 2019-7-17 10:41:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"110 on steers and 100 on rest all year","replyToPid":0}
发表于 2019-7-17 14:01:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"anything of 100-105 psi is perfect..\nfigure...max is 110psi...air expands when heated.\nthe tire is like a med/soft compound graded rubber so to absorb some of the ride and weights in which are carried.\nrunning a tire at Max pressure..you begin to notice...cntr wear of the treads..\nunder 100psi (minimum) you'll see outter tread wear..\na good rule of thumb is to be w/ in 5-7 psi of max pressure \nit doesn't matter if brand new or recaps...100psi and you should be good","replyToPid":0}
发表于 2019-7-17 19:44:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"120 in the steers all year, 110 in the drives.","replyToPid":0}
GMT+8, 2026-4-18 06:36 , Processed in 0.127787 second(s), 24 queries .
