查看: 176|回复: 7
why cant i be content with being single.
 楼主| 发表于 2019-7-16 14:51:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"i ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1632.0,\"name\":\"\",\"url\":\"\",\"width\":1224.0}]","canComment":true}
发表于 2019-7-16 20:18:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"no offense but you seem like you would be a lot of work.  and you have posted on here that you are a two timer.  smart women usually can pick up on that.","replyToPid":0}
发表于 2019-7-16 19:52:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe u should look at the common denominator in all these “girl problems”","replyToPid":0}
发表于 2019-7-16 21:18:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Or you just need to find yourself a woman who is open to the idea of an open marriage. ","replyToPid":0}
 楼主| 发表于 2019-7-17 11:00:10 来自手机 | 显示全部楼层
542330 发表于 2019-07-16 13:18:02 Or you just need to find yourself a woman who is open to the idea of an open marriage.
","text":"that was last relationship","replyToPid":148167}
 楼主| 发表于 2019-7-17 10:59:18 来自手机 | 显示全部楼层
558928 发表于 2019-07-16 12:18:50 no offense but you seem like you would be a lot of work.  and you have posted on here that you are a two timer.  smart women usually can pick up on that.
","text":"i stopped","replyToPid":148113}
发表于 2019-7-16 22:54:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Aren’t you an alcoholic? You’ve got to work on that then go after good women because they’re not going to work on it for you. Dumb women have less value as you get older because you can’t poke them and then you can’t talk to them and then they can’t help you. ","replyToPid":0}
发表于 2019-7-16 16:37:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://youtu.be/6EqFVWzOfN8","replyToPid":0}
GMT+8, 2026-2-11 14:14 , Processed in 0.091225 second(s), 24 queries .
