查看: 340|回复: 15
Cooler for OTR
 楼主| 发表于 2019-7-15 01:49:04 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hey y’all ! So I was wondering what’s the best cooler to get for OTR? I’m looking for something that would keep it around 34F ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-19 08:23:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a Dometic CFX35W. A bit expensive but it works wonderful as my freezer. It can go to -7 but I keep it at 0. It can easily sit at 34 if you want. Quiet and fits perfectly front to back on my top bunk platform. Has both 12v and 115v plugs so you can use either 😁","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-7-19 08:00:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get the Igloo for use now, but start saving your money for a Truckfridge. I bought a chest type model that I can move from truck to truck 16 years ago and it still works great. Your initial investment will be more but you'll come out ahead in the long run.","replyToPid":0}
发表于 2019-7-15 20:39:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like the igloo iceless 40qt, works great for me.","replyToPid":0}
发表于 2019-7-29 22:25:38 来自手机 | 显示全部楼层
599477 发表于 2019-07-19 00:23:36 I have a Dometic CFX35W. A bit expensive but it works wonderful as my freezer. It can go to -7 but I keep it at 0. It can easily sit at 34 if you want. Quiet and fits perfectly front to back on my top bunk platform. Has both 12v and 115v plugs so you can use either 😁
","text":"This!","replyToPid":150416}
发表于 2019-7-17 04:02:33 来自手机 | 显示全部楼层
287806 发表于 2019-07-15 12:39:32 I like the igloo iceless 40qt, works great for me.
","text":"you ever experience the plug heating up and melting it causing the fuse to break?","replyToPid":147153}
发表于 2019-8-1 07:37:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Do NOT waste your money on the Coleman “fridge” that won’t last you past 2 months if you’re lucky I’d grab the koolatron from loves it’s $230 with a $30 mail in rebate a lot better fridge for 100 more","replyToPid":0}
发表于 2019-7-27 05:45:23 来自手机 | 显示全部楼层
713325 发表于 2019-07-16 20:02:33 you ever experience the plug heating up and melting it causing the fuse to break?
","text":"they started packing them with a spare fuse, but no I've never had that problem","replyToPid":148497}
发表于 2019-7-27 05:44:50 来自手机 | 显示全部楼层
708962 发表于 2019-07-15 13:07:45 What type of plug in those it have??
","text":"mine came with ac and DC plugs","replyToPid":147172}
 楼主| 发表于 2019-7-15 21:07:45 来自手机 | 显示全部楼层
","text":"What type of plug in those it have??","replyToPid":147153}
GMT+8, 2026-4-18 12:15 , Processed in 0.125255 second(s), 24 queries .
