查看: 340|回复: 11
How do I tell another truck they need to pull over?
 楼主| 发表于 2019-7-14 21:18:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"saw a truck earlier on I-5 North in California with one of its trailer tires blown out, and it was shredding as they kept driving. I honked and pointed but they didnt understand. any suggestions for next time?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-14 21:24:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get on the cb.. or hand gestures. all you can really do.","replyToPid":0}
发表于 2019-7-14 21:29:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hand gestures like 🖕. They’ll pull over to fight you in the ditch. ","replyToPid":0}
发表于 2019-7-14 22:06:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"if you honk and make gestures, any person who cares would have pulled over. just don't pull over with them because that might scare them. if I had one flat trailer tire and it seemed fine to drive, I'm driving to the next stop where I can get that fixed. it cost a lot to do roadside."}
发表于 2019-7-15 23:42:38 来自手机 | 显示全部楼层
103619 发表于 2019-07-15 04:16:23 must be a rookie skill set... because I'm way advanced... I dont need to look to keep my truck straight down the road
","text":"Ya must be, so I stick my Netflix screen right in front of me. ","replyToPid":147012}
发表于 2019-7-14 23:31:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I tell them hopefully they read lips as well as hand gesture.  I’ll point back to their trailer and then make an explosion gesture. Honk to get their attention 1st. Most of the time they get it and I see them pull over on the shoulder. ","replyToPid":0}
发表于 2019-7-14 22:13:42 来自手机 | 显示全部楼层
366847 发表于 2019-07-14 13:29:18 Hand gestures like 🖕. They’ll pull over to fight you in the ditch.
","text":"Most just ignore you and keep driving.","replyToPid":146378}
发表于 2019-7-15 01:49:52 来自手机 | 显示全部楼层
542330 发表于 2019-07-14 15:31:55 I tell them hopefully they read lips as well as hand gesture.  I’ll point back to their trailer and then make an explosion gesture. Honk to get their attention 1st. Most of the time they get it and I see them pull over on the shoulder.
","text":"You drive where your eyes look so you usually run them off the road doing that. ","replyToPid":146476}
发表于 2019-7-15 03:10:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"Typical California driver. Hope that state falls off the continent ","replyToPid":0}
发表于 2019-7-15 09:11:48 来自手机 | 显示全部楼层
366847 发表于 2019-07-14 17:49:52 You drive where your eyes look so you usually run them off the road doing that.
","text":"Better then dot running them off the road ","replyToPid":146577}
发表于 2019-7-15 12:16:23 来自手机 | 显示全部楼层
","text":"must be a rookie skill set... because I'm way advanced... I dont need to look to keep my truck straight down the road","replyToPid":146577}
GMT+8, 2026-4-18 10:46 , Processed in 0.109846 second(s), 24 queries .
