查看: 393|回复: 8
Right side trailer light not working properly
 楼主| 发表于 2019-7-12 10:11:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can I drive with the ride side of my trailer not working. The lights at the back of trailer work fine just the right side doesnt. It signals but no constant light. And if not how would I fix it. change bulb ? ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-12 10:22:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sometimes I put one of those plastic seals under in the socket of the green hose that connects to the trailer. When ever my lights aren’t blinking or the hazards light or a left or right one. It happens constantly with these trailers that my company has. ","replyToPid":0}
回复 支持 2 反对 4
发表于 2019-7-12 10:23:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you drive like that and a cops see's you he most likely will pull you over, He may give you a warning or a fix a ticket","replyToPid":0}
回复 支持 2 反对 3
发表于 2019-7-12 10:21:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"wiggle the pig tail to see if it's the connection, If it flickers?","replyToPid":0}
回复 支持 2 反对 3
 楼主| 发表于 2019-7-12 12:34:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"I played around with the hose and nothing. since its night time now I see theres very small faint light. But when I signal right it works almost fine. Should I just get it checked out tomorrow or driving for another 4 days and hope dot or cops dont catch ?","replyToPid":0}
回复 支持 0 反对 4
发表于 2019-7-13 00:25:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"look for the spot or spots where someone was working on the harness ie electric tape that is 99 percent of the time where the problem is","replyToPid":0}
回复 支持 0 反对 4
发表于 2019-7-12 12:42:33 来自手机 | 显示全部楼层
709200 发表于 2019-07-12 04:39:27 Some time is grond on the 5 weel or  jonction box  grond on 5 weel hapen to me
","text":"Or slip whit a small screw drive whre you plug the electric cable on trailler don’t bent to much some time they brook","replyToPid":144490}
回复 支持 0 反对 3
发表于 2019-7-12 12:39:27 来自手机 | 显示全部楼层
646385 发表于 2019-07-12 04:34:47 I played around with the hose and nothing. since its night time now I see theres very small faint light. But when I signal right it works almost fine. Should I just get it checked out tomorrow or driving for another 4 days and hope dot or cops dont catch ?
","text":"Some time is grond on the 5 weel or  jonction box  grond on 5 weel hapen to me","replyToPid":144484}
回复 支持 0 反对 3
发表于 2019-7-12 10:56:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"You might want to check your pig tail and fuse box. If you have a Quick starting fluid, spray on both sockets and plugs to clean out debris to get better contact","replyToPid":0}
回复 支持 0 反对 3
GMT+8, 2026-4-17 05:54 , Processed in 0.119706 second(s), 24 queries .
