查看: 404|回复: 12
Crafty
 楼主| 发表于 2019-7-11 21:23:07 来自手机 | 显示全部楼层 |阅读模式
 楼主| 发表于 2019-7-11 23:33:48 来自手机 | 显示全部楼层
719568 发表于 2019-07-11 14:32:21 Couldn't afford to fix the air conditioning unit in their   Generator, So they bought a window unit instead
","text":"Inventive?!?!","replyToPid":143892}
回复 支持 2 反对 2
 楼主| 发表于 2019-7-11 23:47:14 来自手机 | 显示全部楼层
728316 发表于 2019-07-11 15:46:15 C'mon guys it's obviously the top prize back in the 90's you get from IdleAir when you turn in your points.
","text":"Lmao 😂 ","replyToPid":143928}
发表于 2019-7-11 23:46:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"C'mon guys it's obviously the top prize back in the 90's you get from IdleAir when you turn in your points.","replyToPid":0}
发表于 2019-7-11 22:29:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I guess they cannot afford to fix the air conditioning unit in thier generator, so they thought it was cheaper to buy a window unit","replyToPid":0}
发表于 2019-7-12 06:16:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a portable ac in my last truck ran it off a small generator for when I was out on the road doing a 34 reset or longer. saved on running the truck to stay cool","replyToPid":0}
发表于 2019-7-11 23:36:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"inventive, Cheap skate, But not too smart blocking his view. 🤔","replyToPid":0}
发表于 2019-7-11 22:32:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Couldn't afford to fix the air conditioning unit in their   Generator, So they bought a window unit instead","replyToPid":0}
发表于 2019-11-15 14:35:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"what the! lmmfaol","replyToPid":0}
发表于 2019-7-12 03:18:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s ghetto... lol 😝 ","replyToPid":0}
发表于 2019-7-12 03:49:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"I had a mini split on the back of my last truck 😆","replyToPid":0}
GMT+8, 2026-4-19 17:45 , Processed in 0.106141 second(s), 25 queries .
