查看: 377|回复: 13
reaching out. I need to gain weight on my steering axle.
 楼主| 发表于 2019-7-11 10:41:28 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-7-11 11:00:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"Donuts, soda, ice cream. Have your truck eat more calories overall. ","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-8-10 05:52:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"slide your fifth wheel forward. each whole adds anywhere from 250- 500 lbs per hole all depends on your tractor.","replyToPid":0}
发表于 2019-7-11 13:14:04 来自手机 | 显示全部楼层
542330 发表于 2019-07-11 03:24:50 Slide your 5th wheel trailer closer to the truck. Not sure how much it will add but it will put some weight on your steers
","text":"On 5 well is 250 lbs each time you move  and trailler if you old is to 2 inches apart is250 lbs or 6 inches is 600 lbs","replyToPid":143707}
发表于 2019-7-11 19:01:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"what are you pulling? If a reefer be careful because you slide it too far forward a reefer cab get into wind barriers if you turn too tight","replyToPid":0}
发表于 2019-7-11 11:24:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Slide your 5th wheel trailer closer to the truck. Not sure how much it will add but it will put some weight on your steers","replyToPid":0}
发表于 2019-8-5 21:33:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Strap a few Swift drivers to the grill.","replyToPid":0}
发表于 2019-8-3 02:12:49 来自手机 | 显示全部楼层
366847 发表于 2019-07-11 03:00:48 Donuts, soda, ice cream. Have your truck eat more calories overall.
","text":"Exactly","replyToPid":143696}
发表于 2019-7-15 02:57:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"why","replyToPid":0}
发表于 2019-7-11 13:15:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"If is 10.000 on string you go way up to the front","replyToPid":0}
发表于 2019-7-11 13:52:59 来自手机 | 显示全部楼层
709200 发表于 2019-07-11 05:14:04 On 5 well is 250 lbs each time you move  and trailler if you old is to 2 inches apart is250 lbs or 6 inches is 600 lbs
","text":"Correct he was wanting to put weight on his steers not trailer or drives. ","replyToPid":143739}
发表于 2019-7-11 14:06:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ok main point he got weight good like the song no shose no shjrt no problems 😎","replyToPid":0}
 楼主| 发表于 2019-8-2 22:28:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"thx for y'all s feedback","replyToPid":0}
GMT+8, 2026-4-16 12:23 , Processed in 0.147529 second(s), 24 queries .
