查看: 340|回复: 12
What do you do if your ELD breaks while doing a delivery?
 楼主| 发表于 2019-7-11 01:00:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can we avoid getting tickets?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-11 01:01:52 来自手机 | 显示全部楼层
发表于 2019-7-11 11:35:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to have two week of paper logs for backup by law. We carry two books","replyToPid":0}
发表于 2019-7-11 09:24:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"paper logs. but remember you can only use paper for 8 days without an extension","replyToPid":0}
发表于 2019-7-11 01:52:43 来自手机 | 显示全部楼层
542330 发表于 2019-07-10 17:05:21 You use paper logs till fixed. You also need to get your last 7 days emailed or faxed to you as well unless you can still get them to show on eld.
","text":"Arakos is right","replyToPid":143258}
发表于 2019-7-11 01:51:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have to carring paper all the time that what a d o t toll me just in case apen ","replyToPid":0}
发表于 2019-7-11 01:29:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"So true and drivers must have extra paper logs by law are required as a backup in case you have an ELD failure.","replyToPid":143248}
发表于 2019-7-11 03:32:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"paper logs. your suppose to keep some in your truck just in case it does happen","replyToPid":0}
发表于 2019-7-11 01:05:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"You use paper logs till fixed. You also need to get your last 7 days emailed or faxed to you as well unless you can still get them to show on eld. ","replyToPid":0}
发表于 2019-7-11 02:27:14 来自手机 | 显示全部楼层
709200 发表于 2019-07-10 17:51:17 You have to carring paper all the time that what a d o t toll me just in case apen
","text":"That is correct you must carry blank paper logs just Incase eld breaks. ","replyToPid":143296}
发表于 2019-7-11 02:36:17 来自手机 | 显示全部楼层
542330 发表于 2019-07-10 18:27:14 That is correct you must carry blank paper logs just Incase eld breaks.
","text":"Yes blank paper","replyToPid":143330}
发表于 2019-7-11 06:39:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"switch to your paper logs which you are supposed to have with you for just that kinda situation","replyToPid":0}
GMT+8, 2026-4-17 17:07 , Processed in 0.176136 second(s), 25 queries .
