查看: 170|回复: 7
Directions
 楼主| 发表于 2019-7-10 20:34:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"good morning all. I just joined and in trying to get to my destination the route will show the city but I can't get the physical address to pull up??? I typed it in but the map wouldn't show it..any help would be appreciated. Lee","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1759.0,\"name\":\"\",\"url\":\"\",\"width\":1329.0}]","canComment":true}
发表于 2019-7-10 22:25:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google the company name to check the address then use Google maps use the cross streets use them for you GPS then from the cross streets use Google maps","replyToPid":0}
发表于 2019-7-10 21:37:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've had this problem before so I just use Google maps.","replyToPid":0}
发表于 2019-7-10 22:09:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"first make sure you have a strong internet connection. as you type in the address the application should begin bringing up a list that will fit the criteria until you isolate your destination. if this does not work and you have a strong internet connection make sure you don't have to update the program. if you check for those two and it still isn't working correctly oh, I would try to uninstall and then reinstall the program. make sure it is updated oh, and try it again. I switched phones fairly frequently. trucker path does act differently on different phones. Hope this helps. Be safe out there","replyToPid":0}
发表于 2019-7-10 22:12:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"and one more thing because I get this a lot from my dispatch... Make sure you have the right address! Lol I literally received an address from dispatch that's a street address, the street name, and the state we're all wrong. only the city name was correct. as well as the business name which is how I found it on the internet.","replyToPid":0}
发表于 2019-7-10 22:52:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google the address or the company name","replyToPid":0}
发表于 2019-7-11 01:28:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"I just use my phone or look it up because the address might be different. if nothing else call the customer for a physical address","replyToPid":0}
发表于 2019-7-11 03:35:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use Google maps. i locate it with a pin drop and I get the lat and long and put those into my gps","replyToPid":0}
GMT+8, 2026-4-18 10:47 , Processed in 0.076594 second(s), 24 queries .
