查看: 456|回复: 31
s
 楼主| 发表于 2019-7-10 01:43:18 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-7-10 01:58:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"Its for trailer brakes, do not use it while driving. If you want to try how it works, try it when u driving under 5 mph and ready to stop. ","replyToPid":0}
回复 支持 7 反对 0
发表于 2019-7-10 02:12:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"If your trailer ever slides sideways on ice, give it a tug and it’ll pull the trailer back behind ya ","replyToPid":0}
发表于 2019-7-10 03:29:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use when coming down a steep hill to slow down the speed of the trailer. To use, pull and let go just like you do with your foot break","replyToPid":0}
发表于 2019-7-11 06:22:45 来自手机 | 显示全部楼层
449144 发表于 2019-07-09 18:12:09 If your trailer ever slides sideways on ice, give it a tug and it’ll pull the trailer back behind ya
","text":"really? I can't believe I just read that.\n never pull your trailer handle on slick roads or you will jackknife.\n you can use it to slide your tandems or check your 5th wheel.","replyToPid":142536}
 楼主| 发表于 2019-7-10 08:27:36 来自手机 | 显示全部楼层
707730 发表于 2019-07-09 19:54:39 somebody's not been doing their fourth step brake check
","text":"I been driving a freightliner when i started. but when i entered to a new company, they mostly had volvos and everything was new to new to me","replyToPid":142584}
发表于 2019-7-10 07:24:11 来自手机 | 显示全部楼层
679939 发表于 2019-07-09 19:29:52 Use when coming down a steep hill to slow down the speed of the trailer. To use, pull and let go just like you do with your foot break
","text":"NO! you use the brake pedal with hard stabs to lower speed on a down grade. 60% of your breaking through the pedal goes to the trailer. using the Johnny bar on a down grade is a good way to heat the brakes up to the point of fading.","replyToPid":142580}
发表于 2019-7-10 06:02:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"how are you in a truck and not know this ...hmmmm 🤔🤔 bacooćk","replyToPid":0}
发表于 2019-7-10 05:50:18 来自手机 | 显示全部楼层
670977 发表于 2019-07-09 17:58:06 Its for trailer brakes, do not use it while driving. If you want to try how it works, try it when u driving under 5 mph and ready to stop.
","text":"xoxo thank u for helping her","replyToPid":142517}
 楼主| 发表于 2019-7-10 02:03:18 来自手机 | 显示全部楼层
","text":"ah! okay thanks so much! I thought it was to slide the tandem or something and i was doing it wrong","replyToPid":142517}
发表于 2019-7-10 02:26:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"That's the oh chit I'm rolling when stopped on a steep hill handle.","replyToPid":0}
发表于 2019-7-10 02:13:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"Just break on trailler do not tuch on winter you for a ride and a 1/2","replyToPid":0}
发表于 2019-7-10 02:14:18 来自手机 | 显示全部楼层
709200 发表于 2019-07-09 18:13:27 Just break on trailler do not tuch on winter you for a ride and a 1/2
","text":"Go","replyToPid":142539}
发表于 2019-7-10 02:53:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"only time I use it is for tugging the trailer or if I'm at a toll or a gate and need to jump out on the step to reach and don't trust my foot to stay on the brake","replyToPid":0}
发表于 2019-7-10 03:14:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hair ties holder, in my case...","replyToPid":0}
GMT+8, 2026-2-4 06:45 , Processed in 0.108388 second(s), 24 queries .
