查看: 106|回复: 0
Western Star 5700XE Broken sun visor bolt studs
 楼主| 发表于 2019-1-24 15:20:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hi guys, I have recently acquired 2017 Western Star 5700 awesome truck, so far love it. Few minor issues I hope you can suggest how to remedy. When I picked up the truck on the way home I noticed the sun visor was rattling a bit, figured the nuts  needed to be tightened. When I got home I discovered the two lower bolt studs that hold the sun visor bracket are snapped off. When I took off the interior panel above the dashboard from the inside the cab in attempt to reach behind the studs I  discovered the cabin has interior metal layer and the backside of these bolts is unreachable.\n\nHow would you proceed with this repair? I was thinking just welding on two small SS bolts on top to reattach the visor bracket, however that seems like an ugly solution. Has anyone removed these bolts?","pics":"[]","canComment":true}
GMT+8, 2026-2-4 16:57 , Processed in 0.052431 second(s), 23 queries .
