查看: 261|回复: 4
Logging 8/2 split
 楼主| 发表于 2019-7-7 01:41:56 来自手机 | 显示全部楼层 |阅读模式
{"text":"New CDL and just used an 8/2 split to help me stop my 14 hour clock so i would have hours available later in the day to drive between 2 deliveries and get to a safe haven afterwards. I haven't had time to read the regs, but curious if I should log a post trip and go end of shift in the sleeper, or just go on break in the sleeper?  i assumed no end of shift since i was using the split to basically extend my shift. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-7 17:28:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Log a post before the 8 hour SB. Don’t log before the 2 hour OD/SB. ","replyToPid":0}
发表于 2019-7-7 01:46:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re done for the day and parked then just go off duty or sleeper berth. No need for a break ","replyToPid":0}
 楼主| 发表于 2019-7-7 02:12:44 来自手机 | 显示全部楼层
654793 发表于 2019-07-06 17:46:16 If you’re done for the day and parked then just go off duty or sleeper berth. No need for a break
","text":"Thanks.  Since I was effectively pausing my 14 hour clock after just 5 hours of on-duty driving to continue the next day to the receiver, was not sure if i needed to log a post trip before the 8 hours of sleeper berth, then a pretrip before resuming the paused 14 hour clock or not.  even though the 8 hour sleeper berth spanned midnight, i saw it as one trip with an extended break since it was the same 14 hour clock.","replyToPid":140575}
发表于 2019-7-8 10:20:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm trying to find info on this so I can study it. Everyone I ask has a different answer on what they believe is correct .","replyToPid":0}
GMT+8, 2026-3-21 12:52 , Processed in 0.083072 second(s), 24 queries .
