查看: 254|回复: 9
Anyone using Google Maps for routing?
 楼主| 发表于 2019-7-4 05:00:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"Is it trustworthy?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-4 06:49:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Google maps will give you a general idea of what route to take and is great for real time traffic, but as Arakos said it will put you on prohibited routes. There's another app called Road Hunter that I've been playing with. It does a pretty good job of keeping you on truck routes and avoiding low clearance overpasses, but it's not the best when it comes to \"last mile\" directions. It's pretty vague on actual street addresses.","replyToPid":0}
发表于 2019-7-4 08:14:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"I route with it full time. Been using it for almost 5 years. I personally prefer it over any truck gps. Common sense and add a stop option you can make it go anyway you want. Traffic is best. Lot of times if you already have directions you pass up the exit it wants you to take it will usually re route and be spot on.\n\nI also run terminal to terminal now so I know where half of the 225 we have are. Ones that I dont and goto I still use gmaps"}
发表于 2019-7-4 12:37:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"No I ended up in residential area had to curb it to turn I knocked down a couple of stop signs trimming a few trees, But no one saw me, No harm no foul right. 😟","replyToPid":0}
发表于 2019-7-4 06:14:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope will take you on no truck routes ","replyToPid":0}
发表于 2019-7-4 07:47:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"only for traffic conditions. I pay attention to my signs though. google maps will send you down roads that are  not truck friendly","replyToPid":0}
发表于 2019-7-4 08:12:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use it with my Garmin them after a certain point I just follow the Garmin","replyToPid":0}
发表于 2019-7-4 07:32:20 来自手机 | 显示全部楼层
542330 发表于 2019-07-03 22:14:53 Nope will take you on no truck routes
","text":"Yes sir it's only good for locating the address or building.","replyToPid":138842}
发表于 2019-7-4 07:42:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s great if your not driving a truck. It does not specify for weight restricted roads or bridge height ect.","replyToPid":0}
发表于 2019-7-4 07:54:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"give you a rough idea. it will take you on roads you are not supposed to be on like posted roads posted bridges low clearance bridges.","replyToPid":0}
GMT+8, 2026-4-18 12:29 , Processed in 0.099958 second(s), 24 queries .
