查看: 427|回复: 32
Dam roads 😠😤😡🤯🤬
 楼主| 发表于 2019-7-4 01:44:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"So for the win n gold USA medals \ndriving thru PA roads i will attempt 3 front flips 2 Twist jumps thru NJ 4 cart wheels thru CT 2 side extension jumps thru RI then 4 backwards flips thru Mass then get on the rail beams n slide thru them n jump into a side twist back into RI n drive backwards n do a 360* spin n roll out like a G on all wheels touching the ground into my company terminal. \n\nNow I need some cheerleaders 📣 to amp me up, so I can get started. \n😠😤🥺🤯🤬😳🙆🏻‍♀️🤦🏻‍♀️🤷🏻‍♀️\nThat’s how F%€£¥•?!CKed up these roads are. \n","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-7-4 05:37:44 来自手机 | 显示全部楼层
740796 发表于 2019-07-03 21:36:57 seems like 40 miles another $30 toll ..tolls everywhere with the worst roads
","text":"Exactly!! They take our money n nothing gets done ","replyToPid":138812}
发表于 2019-7-4 05:36:57 来自手机 | 显示全部楼层
发表于 2019-7-4 02:59:19 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
 楼主| 发表于 2019-7-4 07:59:26 来自手机 | 显示全部楼层
696565 发表于 2019-07-03 23:41:46 Indianapolis are finally repairing and resurfacing their roads! chicago and ny need to join the club.
","text":"Good the whole north East needs to hurry up n get with the program ","replyToPid":138894}
 楼主| 发表于 2019-7-4 05:36:58 来自手机 | 显示全部楼层
711455 发表于 2019-07-03 18:47:01 LMFAO SO TRUE. 😂🤣🤣😂😂
","text":"Unbelievable N it looks like nothing is ever being done, they’ve been working on the road since last decade. 😳🤦🏻‍♀️🤷🏻‍♀️🤬","replyToPid":138697}
 楼主| 发表于 2019-7-4 05:35:17 来自手机 | 显示全部楼层
63824 发表于 2019-07-03 18:59:19 in Shreveport La I20 you need a helmet & 5 point seat belt
","text":"Yes indeed I always hit my Heazd bouncing up n down smh 🤦🏻‍♀️ 🙆🏻‍♀️🤷🏻‍♀️","replyToPid":138703}
 楼主| 发表于 2019-7-4 05:34:07 来自手机 | 显示全部楼层
658864 发表于 2019-07-03 19:05:36 I feel your pain!  Broke a leaf spring in NJ last week...
","text":"Yeah I always feel like something broke n when I pull over I check everything to see if ok. Lmao 😂 ","replyToPid":138717}
发表于 2019-7-4 03:05:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"I feel your pain!  Broke a leaf spring in NJ last week... ","replyToPid":0}
发表于 2019-7-4 02:47:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"LMFAO SO TRUE. 😂🤣🤣😂😂","replyToPid":0}
 楼主| 发表于 2019-7-4 05:35:01 来自手机 | 显示全部楼层
","text":"Yes indeed I always hit my head bouncing up n down smh 🤦🏻‍♀️ 🙆🏻‍♀️🤷🏻‍♀️","replyToPid":138703}
GMT+8, 2026-4-19 15:47 , Processed in 0.093915 second(s), 25 queries .
