查看: 234|回复: 11
Light engines on ( including the red one) Engine derate 25% I can only drive 5 miles/hr Ecc 5 -Poor def quality
 楼主| 发表于 2019-7-3 10:16:32 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-7-3 10:48:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Had the same on my W900. Once I changed the filters I was good to go for a while. ","replyToPid":0}
发表于 2019-7-3 10:43:05 来自手机 | 显示全部楼层
625878 发表于 2019-07-03 02:41:38 💯 % you need a regen. Plus it sounds like something is in your DEF tank. Take it to a shop
","text":"Not necessarily. I’ve had these codes on lack of maintenance. Very neglected filter that’s super easily replaced. Freightliner is the easiest and cheapest to do. Much like 90% of their maintenance. I say this as a kw/ Pete fan...","replyToPid":138182}
发表于 2019-7-3 20:00:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"You need to remove your DEF filter and send it out to \"Bake\" the excess build up of soot in it, cost to bake = around $1400.00\n  Cost to swap out with new around $3000.00\n Baking is just as good as new","replyToPid":0}
发表于 2019-7-3 12:00:06 来自手机 | 显示全部楼层
740735 发表于 2019-07-03 02:37:05 Find a shop that’ll swap the spinon filter and do a regen. Try to do the spin on def filter every second or 3rd pm. I recommend boss truck shops. Just a personal preference
","text":"Shot the kill swich whaite 1or 2 min and put the kill switch at on and try","replyToPid":138178}
 楼主| 发表于 2019-7-3 11:33:04 来自手机 | 显示全部楼层
","text":"Not a regen,  I tried force regen When the problem started a week ago on Ta shop. ","replyToPid":138182}
发表于 2019-7-3 10:37:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Find a shop that’ll swap the spinon filter and do a regen. Try to do the spin on def filter every second or 3rd pm. I recommend boss truck shops. Just a personal preference ","replyToPid":0}
发表于 2019-7-3 10:45:43 来自手机 | 显示全部楼层
625878 发表于 2019-07-03 02:44:26 Yea you could be correct again.
","text":"Personal experience 😉 not all wrench monkeys are jerks only the ones theatre rushed and have to hear complaining.... ","replyToPid":138185}
发表于 2019-7-3 10:48:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Shops are spendy but some are worth waiting for... just my two cents","replyToPid":0}
发表于 2019-7-3 12:01:05 来自手机 | 显示全部楼层
709200 发表于 2019-07-03 04:00:06 Shot the kill swich whaite 1or 2 min and put the kill switch at on and try
","text":"I did do it work for me","replyToPid":138270}
发表于 2019-7-3 12:53:34 来自手机 | 显示全部楼层
560800 发表于 2019-07-03 03:33:04 Not a regen,  I tried force regen When the problem started a week ago on Ta shop.
","text":"Poor quality usually indicates a blockage or poor filtration. Take it to someone who knows more than TA (someone with a pulse) and get it fixed ","replyToPid":138246}
GMT+8, 2026-4-19 06:00 , Processed in 0.173582 second(s), 24 queries .
