查看: 485|回复: 14
Low AIr Pressure
 楼主| 发表于 2019-7-3 06:47:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"So I am experiencing tractor air pressure that is abnormal. No air leaks, but the tractor air pressure sometimes drops low enough for the red indicator warning to display. The trailer air pressure stays at 125 while the tractor pressure is all over the place. (2018 Cascadia)\n\nAny ideas? I would hate for my brakes to lock up....","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-3 10:17:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"also check your air tank governor valve for dirt and debris. it can make it stick open so it wont build air pressure.","replyToPid":0}
发表于 2019-7-3 09:22:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check o rings on glad hands or your pressure relief solenoid could be staying open to long ","replyToPid":0}
 楼主| 发表于 2019-7-4 01:38:59 来自手机 | 显示全部楼层
625878 发表于 2019-07-03 02:36:27 Do you find you lose air on the tractor when you apply your foot pedal. If you do it is a brake pod.
","text":"Yes - this!","replyToPid":138177}
发表于 2019-7-3 10:16:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"so on my freightliner cascadia i had thos happen. give you air cleaner a good shake out. ik it sounds stupid af but thats what they did to correct that same problem for me last week.","replyToPid":0}
发表于 2019-7-3 10:31:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check for pinholes. First in your hand valves on the dash. Then the valves at the firewall. Then check at your airbags and the most common is a push lock fitting at the air tanks. ","replyToPid":0}
发表于 2019-7-3 10:50:18 来自手机 | 显示全部楼层
","text":"Highly unlikely as it is audible and not near as frequent. Most manufacturers make parts of expandable plastic that hold pressure. We call it k.i.s.s.","replyToPid":138177}
发表于 2019-7-3 11:16:52 来自手机 | 显示全部楼层
740735 发表于 2019-07-03 02:50:18 Highly unlikely as it is audible and not near as frequent. Most manufacturers make parts of expandable plastic that hold pressure. We call it k.i.s.s.
","text":"Look like compressor tired or the west gate ","replyToPid":138196}
发表于 2019-7-3 11:22:17 来自手机 | 显示全部楼层
709200 发表于 2019-07-03 03:16:52 Look like compressor tired or the west gate
","text":"Too far in depth. It would be an unloader valve or governor. ","replyToPid":138219}
发表于 2019-7-3 11:41:20 来自手机 | 显示全部楼层
740735 发表于 2019-07-03 03:22:17 Too far in depth. It would be an unloader valve or governor.
","text":"Or a hose start to block from compressor to the air tank appen to me the hose in side  a size of the pin","replyToPid":138227}
发表于 2019-7-3 12:01:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"my classic did the same thing replaced governor didn't work. ended up having to take the air dryer apart replaced the element and cleaned everything worked great","replyToPid":0}
GMT+8, 2026-2-4 12:27 , Processed in 0.081635 second(s), 24 queries .
