查看: 278|回复: 11
over weight
 楼主| 发表于 2019-5-14 07:28:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"has anyone gotten a citation for over weight, and how did it go? Do they just cite you and let you go? how much was the citation? Just curious for a friend. thanks.","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-5-14 14:16:39 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"none of this sounds too bad, here I am, worrying for nothing."}
发表于 2019-5-14 09:29:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always scale your load","replyToPid":0}
发表于 2019-5-14 09:08:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"$1 / lb. overweight","replyToPid":0}
发表于 2019-8-2 06:36:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"BUILD THE WALL 😂🤣😂","replyToPid":0}
发表于 2019-5-29 06:24:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"One in limon CO. Was over 200lbs on spread axle the dot was cool and gave me some slack and cited me for $95 and then in Illinois on I55 was over on van around 200 something pounds and that came out to around $400 ","replyToPid":0}
发表于 2019-5-19 15:24:42 来自手机 | 显示全部楼层
462372 发表于 2019-05-15 12:18:22 what's an 85% road ban? they give you certain routes you can only take?
","text":"They dictate max weight on certain roads when the frost is coming out so u don’t tear up the road ","replyToPid":35208}
 楼主| 发表于 2019-5-15 20:18:22 来自手机 | 显示全部楼层
133776 发表于 2019-05-14 15:46:40 1,000 $ in Tok Alaska. 8,000 lb overweight at 85% road ban
","text":"what's an 85% road ban? they give you certain routes you can only take?","replyToPid":34508}
发表于 2019-5-14 23:46:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"1,000 $ in Tok Alaska. 8,000 lb overweight at 85% road ban ","replyToPid":0}
发表于 2019-5-14 22:00:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"Illinois got me for 200 lbs over on drives, slid the tandems, still cost me, the driver, $513.","replyToPid":0}
发表于 2019-5-14 20:49:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"In IL is 1$ /lbs","replyToPid":0}
GMT+8, 2026-2-16 05:10 , Processed in 0.072246 second(s), 24 queries .
