查看: 380|回复: 22
so my fuel light went on and I have a hundred miles to go does anyone know how many miles these trucks can go
 楼主| 发表于 2019-7-1 11:42:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/124851/android_725725_1561952454174.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":720.0,\"name\":\"\",\"url\":\"\",\"width\":1242.0}]","canComment":true}
发表于 2019-7-1 11:50:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Not a hundred why’d you even let it get that low ","replyToPid":0}
发表于 2019-7-2 00:22:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've been at this for 42 years   full of thumb, stick  your tank, you'll probably have 6 inches of fuel in each tank, 100 miles divided by 4 miles per gallon equal 25 gallons, that's 12.5 per tank,, you'd have enough to go the 100 miles,,its amazing how now a day drivers don't know old school ways","replyToPid":0}
发表于 2019-7-1 21:16:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"you will have to get to know your own truck. Each truck is different. it depends are you in the mountains on Flatlands? what is your tank capacity? how heavy are you running? are you on expressway driving or city driving? what top speed are you running? there are so many factors involved no one can answer that question for you and it's just something that you're going to have to learn about your truck little by little. be safe out there brothers and sisters","replyToPid":0}
发表于 2019-7-1 15:52:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"Every truck has different fuel tank sizes. ","replyToPid":0}
发表于 2019-7-1 11:55:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get fuel now!!!! Keep running that truck on low fuel you will be replacing the fuel injectors soon ","replyToPid":0}
发表于 2019-7-1 15:23:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"By this time you should already got some fuel.\nbut it's always a good habit to refuel once your needle goes under the 1st quarter of the tank not the red zone tho.\nAlso check the the menu on the trucks display it will tell you how many gallons you have left and how far you can go.\nNot always accurate but it will give you an idea.\n✌️","replyToPid":0}
发表于 2019-7-2 03:05:43 来自手机 | 显示全部楼层
719568 发表于 2019-07-01 16:22:39 I've been at this for 42 years   full of thumb, stick  your tank, you'll probably have 6 inches of fuel in each tank, 100 miles divided by 4 miles per gallon equal 25 gallons, that's 12.5 per tank,, you'd have enough to go the 100 miles,,its amazing how now a day drivers don't know old school ways
","text":"I’m a younger driver but the old man taught me the old ways. And that’s how we did it shoot I learned how to shift and drive off road in a 1985 Mack dump truck. Thanks for the reminder great memories and a lot of yelling if I scrubbed those gears. Stay safe driver","replyToPid":136873}
发表于 2019-7-1 12:00:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"I always fill up between half and a quarter, I know how expensive fuel injectors can be for any vehicle 😟","replyToPid":0}
发表于 2019-7-2 06:32:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nope... Not true. Sludge does not accumulate in the bottom of fuel tank, (unless it's intentionally put there), and you can't just suck it up into the engine.\nNor is it a safety thing... Diesel fuel is combustible not flammable, it does not explode for shits and giggles.\nThe amount in the bottom of a diesel fuel tank is not enough to set off the earth shattering KABOOM you have envisioned after introducing air to the fumes... Reason being... Air is already in the tank, tanks are vented. 2 reasons... 1, so the tank don't collapse as fuel is sucked out of it. 2, to prevent the rapid introduction of air thus causing the explosion some highly scientific drivers believe would happen.","replyToPid":0}
发表于 2019-7-1 22:02:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"it is wise to get a feel for your trucks mileage and your driving style. most trucks have a trip meter and a leg meter. I reset my leg meter everytime I fuel. when I fuel, I fuel all the way. on my truck that's about 200 gallons. my truck averages abut 6.8 to 7.4 depending on where I run & load size. I try to never fall below 50 gallons on the truck.( I only reset the trip meter when I go home for hometime. ) never let your tank get down into the red/lights on if you can help it. one it's a maintenance thing: sludge accumulates at the bottom, you'll suck it up into the engine. two it's a safety thing. if you are in an accident with near empty tanks the possibility of explosion goes up, the fuel to air ratio is more conducive to ignition than full tanks. full tanks = less air. yes there is more diesel to clean up, but you might escape because the fuel tanks didn't explode.","replyToPid":0}
发表于 2019-7-2 00:39:07 来自手机 | 显示全部楼层
GMT+8, 2026-4-17 22:48 , Processed in 0.154130 second(s), 24 queries .
