查看: 158|回复: 17
ok my fuel light came on. lil while ago.im stuck at Wal-Mart.its at the red line between the 2nd 3rd.can i run my tri-pa
 楼主| 发表于 2019-7-1 07:50:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"c and still drive 19 miles in the morning? help","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-7-1 08:09:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"you shouldn't run you're apu on an 1/8th of a take itll pick up all that trash and sediment from the bottom to your filters","replyToPid":0}
发表于 2019-7-1 08:55:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"The minute you see the light come on you can go an additional 160 miles \"Standard\"!!!","replyToPid":0}
发表于 2019-7-1 08:17:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don't have an APU, however whenever my gas light comes on i have 150 miles yet.","replyToPid":0}
发表于 2019-7-1 08:13:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"i dont have an apu so i cant speak to that but ive driven 100 miles after my light came on. i have 200 gal tank","replyToPid":0}
发表于 2019-7-1 09:12:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I wouldn’t recommend running the apu with that little fuel as you’ll get a lot of the debris which will clog up that tiny filter and make your fuel pump work that much harder. \n\nYou can though and should be fine to get to a fuel stop that is that close. ","replyToPid":0}
发表于 2019-7-2 07:43:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"Guys, it's good to try to help other guys out with advice and guidance, especially new guys.\nBut be careful. So guys really \"don't know\" and will take what you say as fact or law or whatever.\nThey get in a bind, think the world's against them, never get married, never have kids who discover a cure for cancer or the common cold because they off'd themselves all because of 3.5 to 4 gallons of diesel.\nSo just be careful.","replyToPid":0}
发表于 2019-7-1 09:10:30 来自手机 | 显示全部楼层
70497 发表于 2019-07-01 00:55:47 The minute you see the light come on you can go an additional 160 miles \"Standard\"!!!
","text":"Tell that to Volvo. When I owned my Volvo I ran it out on purpose to see how far I could go after light came on.  Was 82 miles. ","replyToPid":136421}
发表于 2019-7-1 08:25:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"19 miles need about 3.5 - 4 gallons. APU burn about 1 gallon every 4 hours. With the capacity of your tanks make the calculation","replyToPid":0}
发表于 2019-7-1 08:49:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I was always taught not to trust the tank in red... but we also get roadside. Problem being is the fule gage is not always as actuate as it should be. Go up a slight uphill and you'll start stalling since all the diesel shifts to the back.","replyToPid":0}
发表于 2019-7-1 08:01:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you have an 8th of a tank you should be fine","replyToPid":0}
 楼主| 发表于 2019-7-1 08:38:14 来自手机 | 显示全部楼层
179510 发表于 2019-07-01 00:25:52 19 miles need about 3.5 - 4 gallons. APU burn about 1 gallon every 4 hours. With the capacity of your tanks make the calculation
","text":"my tanks r pretty big i just looked in them with my flash light.there is at least 2 inches in each of them what do u think?","replyToPid":136383}
GMT+8, 2026-2-11 15:45 , Processed in 0.069803 second(s), 24 queries .
