查看: 138|回复: 4
Question to the diesel mechanics on this app
 楼主| 发表于 2019-6-29 23:25:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"While driving my engine died, both the check engine lights came on and the smell of diesel came thru the vents. Now the engine rolled over like normal when I started it. I was able to get safely to a shop but I was wondering what it was that shut my engine off while driving? Any thoughts?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-30 01:24:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Seen that with plugged fuel filters","replyToPid":0}
发表于 2019-6-30 02:17:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check your fuel pump, fuel rail and or injector lines for leaks.","replyToPid":0}
发表于 2019-6-30 02:45:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"does it have an over rev cutoff for volatile environments?","replyToPid":0}
 楼主| 发表于 2019-6-30 09:36:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"It was a corroded fuel line","replyToPid":0}
GMT+8, 2026-4-19 21:46 , Processed in 0.088647 second(s), 24 queries .
