查看: 388|回复: 20
I’m four hours away from home there is anyway I can get home with no trouble with the E log?????? Help
 楼主| 发表于 2019-6-29 09:53:44 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-6-29 10:40:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Dude PC ain’t for 4hrs of driving. PC gets you from a consignee to the rest area, from your local terminal home while empty, from your rest area to entertainment and back to that same rest area. You can’t advance the load with pc time. You 4 hrs from home, the sooner you go into the sb the sooner that 10 will be done. ","replyToPid":0}
回复 支持 6 反对 0
发表于 2019-6-29 11:22:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"PC on PeopleNet is only 50 miles.\nlast night I was 58 miles out, crawled into bed drove home in the morning. I deliver on Monday. That's just what you have to do. It Sûçks, but so does a ticket.","replyToPid":0}
发表于 2019-6-29 10:03:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Log in personal conveyance or call someone to pick you up.","replyToPid":0}
 楼主| 发表于 2019-6-29 10:06:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"The said I can’t login to personal when have load it’s that right?","replyToPid":0}
发表于 2019-6-29 10:36:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"PC ain’t covering 4hrs!","replyToPid":0}
发表于 2019-6-29 23:13:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"got to your unload area sit for about 20min then turn on pc time. go home then go back to same area on pc time clock in. just don't get stopped while on pc time. later if dot checks logs just say you dropped trailer and went home for a bit","replyToPid":0}
发表于 2019-6-29 11:21:52 来自手机 | 显示全部楼层
Thanks bro
{"replyToPid":134739,"replyTo":"","text":"odds of you being caught is small. that's why cops only look at 7 days, it's a cat and mouse.game.where you still feel like you have a chance. you're the mouse btw"}
发表于 2019-6-29 11:47:44 来自手机 | 显示全部楼层
366847 发表于 2019-06-29 02:40:29 Dude PC ain’t for 4hrs of driving. PC gets you from a consignee to the rest area, from your local terminal home while empty, from your rest area to entertainment and back to that same rest area. You can’t advance the load with pc time. You 4 hrs from home, the sooner you go into the sb the sooner that 10 will be done.
","text":"ive driven 2000 miles on pc","replyToPid":134694}
 楼主| 发表于 2019-6-29 11:19:38 来自手机 | 显示全部楼层
","text":"Thanks bro ","replyToPid":134694}
发表于 2019-6-29 23:14:46 来自手机 | 显示全部楼层
发表于 2019-6-29 10:17:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"put that foot down... and run as hard as h××× ... you that close to home... dont think I would stop then...","replyToPid":0}
发表于 2019-6-29 10:17:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can be laden on personal conveyance. It’s up to your company if they let you go home. ","replyToPid":0}
GMT+8, 2026-4-18 10:26 , Processed in 0.137304 second(s), 24 queries .
