查看: 56|回复: 0
2011 Volvo D13 STOP engine fault
 楼主| 发表于 2019-1-24 14:25:25 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have a 2011 volvo, D13 engine, I-Shift, and while pulling the trailer uphill, I keep getting the Stop Engine Fault message. Everytime I pull over, I stop the engine, pop the hood and I can see the coolant boiling but the water temperature gauge doesn't go over 200degrees. I had it in 3different Volvo dealerships, they replaced The EGR cooler, they tested the truck but didn't get any error on the computer. They also changed the thermostat. About a month ago I had the water pump replaced, the coolant tank and all the hoses and I have no leak whatsoever. Probably not related, but I also get a message on dashboard saying 'tractor front parking light open circuit' and other Check lights messages. I have no issues when bobtailing. Any ideas on what the problem might be? Thank you.","pics":"[]","canComment":true}
GMT+8, 2026-2-4 12:14 , Processed in 0.061739 second(s), 23 queries .
