查看: 60|回复: 2
does my tri-pac also run my inverter?
 楼主| 发表于 2019-6-28 09:20:24 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-6-28 17:55:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"if the voltage on your inverter shows more than 12.6-12.8 volts while running, yes, if not, no. Mine does not but it has the potential to, just too lazy to check mine. if I run my APU for about eight hours, my batteries are drained 😭","replyToPid":0}
 楼主| 发表于 2019-6-28 21:38:16 来自手机 | 显示全部楼层
462372 发表于 2019-06-28 09:55:11 if the voltage on your inverter shows more than 12.6-12.8 volts while running, yes, if not, no. Mine does not but it has the potential to, just too lazy to check mine. if I run my APU for about eight hours, my batteries are drained 😭
","text":"thank u","replyToPid":133877}
GMT+8, 2026-2-11 16:03 , Processed in 0.056362 second(s), 23 queries .
