查看: 228|回复: 29
Do you know?
 楼主| 发表于 2019-6-28 08:50:02 来自手机 | 显示全部楼层 |阅读模式
{"text":"Hello, please could someone explain to me how I can legally carry my gun while driving through the 48 states, my gun is legal and with permission to carry in Florida, it is only for personal defense, as I drive through dangerous areas and I put  my life at risk by the mere fact of being working outside the home.  THANK YOU","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-28 17:51:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're going to be fine, you're probably more likely to be killed in an accident than anything else.","replyToPid":0}
发表于 2019-6-28 17:27:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"Your Florida gun license is good only for states that have reciprocity agreements with Florida. Possibly they are listed on the back of your license itself. Your Florida license is not good for all states. If you are examined by DOT in a state or locality that does not recognize your Florida license you will be arrested for carrying a concealed weapon.","replyToPid":0}
发表于 2019-6-28 17:44:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"An unless owner operator better check with your company an know what there policy is.","replyToPid":0}
发表于 2019-6-29 05:01:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"you do not have to have retro prosody in all 48 states. you just have to understand each State's law about transporting firearms in the ones that are not covered under retro prosody with Florida. you can legally travel to all states you just have to understand each State's law about transporting that firearm and how has to be secured.","replyToPid":0}
发表于 2019-6-29 00:48:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"You'll shoot your eye out kid.","replyToPid":0}
 楼主| 发表于 2019-6-29 01:02:56 来自手机 | 显示全部楼层
711455 发表于 2019-06-28 16:46:51 Whatever makes you feel safer, I believe that the choice should be the driver's, I personally wouldn't carry a firearm, I personally have not felt the need too do so even growing up in a bad neighborhood, In my experiences thing's just escalate too quickly and in a flash your life changes forever, Good or Bad There's many consequences to be held accountable for.✌
","text":"This is a problem that is better not having it, it is one of two or your life or your freedom.  And being imprisoned in a cell for many years is also not life","replyToPid":134150}
发表于 2019-6-28 23:19:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"Who cares?  Everyone has one.","replyToPid":133914}
发表于 2019-6-28 23:10:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can't legally carry unless your carry permit is reciprocated in all 48 so all the blue states like Ca,IL,Ny,","replyToPid":0}
发表于 2019-6-28 17:43:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"I don’t think there is one that covers all of the 48.  I used same site to see where can carry.","replyToPid":0}
发表于 2019-6-29 05:11:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you choose to carry your firearm you're really need to know the laws. with a CCW you can carry and all states that reciprocate your States CCW. the other states that do not reciprocate your CCW you must abide by their laws .such as we will use California for example. the gun must be unloaded the magazine must be unloaded and all put in a locked case not within reach of the driver. this does render the gun useless but that's California. you can transport your firearm through ALL states you just have to know how you need to transport the firearm. you also need to know weather the state that you are in is a DUTY TO INFORM STATE meaning do you have to inform the law enforcement officer of the firearm upon the  first initial contact. this is the number one thing that will get you jacked up you might be legal to carry in that state but you didn't inform the officer of having a firearm at the initial contact. and he found it later.","replyToPid":0}
发表于 2019-6-28 17:29:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"https://www.usconcealedcarry.com/resources/ccw_reciprocity_map/fl-gun-laws/","replyToPid":0}
发表于 2019-6-28 17:44:12 来自手机 | 显示全部楼层
505517 发表于 2019-06-28 09:27:58 Your Florida gun license is good only for states that have reciprocity agreements with Florida. Possibly they are listed on the back of your license itself. Your Florida license is not good for all states. If you are examined by DOT in a state or locality that does not recognize your Florida license you will be arrested for carrying a concealed weapon.
","text":"https://youtu.be/N0Wn3Eey6dY","replyToPid":133870}
 楼主| 发表于 2019-6-28 20:13:50 来自手机 | 显示全部楼层
","text":"ok thank you 👍","replyToPid":133870}
 楼主| 发表于 2019-6-28 20:17:38 来自手机 | 显示全部楼层
690887 发表于 2019-06-28 09:44:57 An unless owner operator better check with your company an know what there policy is.
","text":"👍","replyToPid":133874}
 楼主| 发表于 2019-6-28 20:17:50 来自手机 | 显示全部楼层
462372 发表于 2019-06-28 09:44:12 https://youtu.be/N0Wn3Eey6dY
","text":"👍","replyToPid":133873}
GMT+8, 2026-2-8 18:18 , Processed in 0.053701 second(s), 24 queries .
