查看: 411|回复: 20
Pulled over twice in one for Level two and level 3 inspection
 楼主| 发表于 2019-6-27 21:50:38 来自手机 | 显示全部楼层 |阅读模式
{"text":"So what does the DOT want E log or paper log I got cited for not having blank paper log and for not having my E log mounted to my dash ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-28 00:14:21 来自手机 | 显示全部楼层
654793 发表于 2019-06-27 14:54:08 What is their reasoning for requiring it’s mounted?
","text":"I looked it up \nDo eld have to be mounted?\n\nYes. A driver may use a portable ELD. A portable ELD must be mounted in a fixed position during commercial motor vehicle (CMV) operation (CMV) and visible to the driver from a normal seated driving position. This informationcan be found in the ELD Rule section 395.22(g).","replyToPid":132915}
发表于 2019-6-28 00:17:37 来自手机 | 显示全部楼层
","text":"I looked it up of course they didn't allow me to post it here, But they don't give a reason but it  does say it has to be mounted also it didn't specify on the dash though.","replyToPid":132915}
发表于 2019-6-28 10:21:18 来自手机 | 显示全部楼层
711455 发表于 2019-06-27 17:31:01 Yes the instruction booklet. That's due to the Cops don't know all the different types of ELD's
","text":"So why would they want to see instructions?  Cops can read....lol","replyToPid":133018}
发表于 2019-6-28 06:38:42 来自手机 | 显示全部楼层
289718 发表于 2019-06-27 20:00:08 yes bit if you dont have it that's a fine I've been told. pretty sad we can get fined for everything now. what's this world coming to.
","text":"I agree 100%","replyToPid":133176}
发表于 2019-6-28 06:37:52 来自手机 | 显示全部楼层
289718 发表于 2019-06-27 16:51:03 yea there is no real reason but I got a warning cause mine wasn't. said it has to be mounted to so you can view it. they got different king of mounts on Amazon
","text":"I'll look onto it thanks for the info.","replyToPid":132983}
发表于 2019-6-28 01:31:01 来自手机 | 显示全部楼层
289718 发表于 2019-06-27 14:47:19 and you have to have it mounted somewhere. and just in case they didnt check but you also have to have the directions on how your blog works
","text":"Yes the instruction booklet. That's due to the Cops don't know all the different types of ELD's","replyToPid":132911}
发表于 2019-6-28 00:28:30 来自手机 | 显示全部楼层
727602 发表于 2019-06-27 16:25:18 good stuff!! mind's mounted but I never knew you had to have it mounted..
","text":"I didn't know, I have to get mine mounted.","replyToPid":132974}
发表于 2019-6-28 00:51:03 来自手机 | 显示全部楼层
711455 发表于 2019-06-27 16:28:30 I didn't know, I have to get mine mounted.
","text":"yea there is no real reason but I got a warning cause mine wasn't. said it has to be mounted to so you can view it. they got different king of mounts on Amazon","replyToPid":132975}
发表于 2019-6-27 22:11:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"what state u in?","replyToPid":0}
发表于 2019-6-27 22:54:08 来自手机 | 显示全部楼层
","text":"What is their reasoning for requiring it’s mounted?","replyToPid":132911}
发表于 2019-6-27 22:03:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"U have to have paper as a backup in case ur elog goes down ","replyToPid":0}
发表于 2019-6-27 22:47:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"and you have to have it mounted somewhere. and just in case they didnt check but you also have to have the directions on how your blog works","replyToPid":0}
 楼主| 发表于 2019-6-27 22:50:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tx","replyToPid":132897}
发表于 2019-6-27 23:05:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"i hope i never get pulled over.","replyToPid":0}
发表于 2019-6-28 00:25:18 来自手机 | 显示全部楼层
711455 发表于 2019-06-27 16:17:37 I looked it up of course they didn't allow me to post it here, But they don't give a reason but it  does say it has to be mounted also it didn't specify on the dash though.
","text":"good stuff!! mind's mounted but I never knew you had to have it mounted..","replyToPid":132965}
GMT+8, 2026-3-20 22:42 , Processed in 0.087009 second(s), 24 queries .
