查看: 130|回复: 4
Can i use a different eld on my truck than the one installed in this truck ? company's eld is complicated mine is easy
 楼主| 发表于 2019-6-26 02:31:30 来自手机 | 显示全部楼层 |阅读模式
发表于 2019-6-26 05:34:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only if your company allows it. The company needs access to your logs   ","replyToPid":0}
发表于 2019-6-27 01:30:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"When I worked for US Express I did.  Just a word of advice is that if you are ever inspected by DOT or at a Scale House YOU DO NOT show or mention that you have a second device.The reason why is the Law can misinterpret your thoughts & reasoning behind it. What I am technically saying is that in the eyes of the law you are illegally running  2 log books  Nobody wants that ticket or fine.  So just be careful out there.","replyToPid":0}
 楼主| 发表于 2019-7-8 07:16:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"thank you guys for your help... ive just decided to carry on with my company's dumb eld ...cuz the one i use can be run into what they call \"ABORD\"mode which our lawmakers have decided to label as an illegal eld device cuz it saved drivers a lot of time .... man this is just sad  😕","replyToPid":0}
发表于 2019-7-8 10:18:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes I run 3 different kinds","replyToPid":0}
GMT+8, 2026-4-18 10:32 , Processed in 0.084735 second(s), 24 queries .
