查看: 187|回复: 20
ok.i messed up the first thing this morning.i backed up to get my trailer.and the king pin we over the 5th wheel.took me
 楼主| 发表于 2019-6-26 01:08:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"a hour to get it off.made me 20 minutes late.first and last time thats happening.night mare.not to mention all the grease i got all over everything","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-26 01:13:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep a 2x4 handy. If it happens again use it to push the high end of your 5th wheel down so it’s lower than the kingpin. Then just pull forward and the kingpin will go right over the plate. ","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-6-26 01:33:45 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"it happen to me when I was a pup"}
发表于 2019-6-26 02:14:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"put a bungee cord on the handle and dump ur airbags take 5 min","replyToPid":0}
发表于 2019-6-26 01:57:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've done it.  thank goodness I had that piece of wood to fix it.","replyToPid":0}
发表于 2019-6-26 01:24:50 来自手机 | 显示全部楼层
669771 发表于 2019-06-25 17:13:03 Keep a 2x4 handy. If it happens again use it to push the high end of your 5th wheel down so it’s lower than the kingpin. Then just pull forward and the kingpin will go right over the plate.
","text":"How! Lol","replyToPid":131287}
发表于 2019-6-26 01:25:29 来自手机 | 显示全部楼层
","text":"I used an empty plastic bottle ","replyToPid":131287}
发表于 2019-6-26 01:19:51 来自手机 | 显示全部楼层
704132 发表于 2019-06-25 17:15:17 thanks.yeah thats the first time so it was a learning experience..thanks for the tip.2×4 wood have worked perfect
","text":"No problem. Sometimes bad things happen. We’ve all been there. Hope your day gets better. ","replyToPid":131290}
发表于 2019-6-26 01:13:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take a few pics and share next time to help other newbies ","replyToPid":0}
 楼主| 发表于 2019-6-26 01:15:17 来自手机 | 显示全部楼层
","text":"thanks.yeah thats the first time so it was a learning experience..thanks for the tip.2×4 wood have worked perfect","replyToPid":131287}
 楼主| 发表于 2019-6-26 01:56:08 来自手机 | 显示全部楼层
669771 发表于 2019-06-25 17:19:51 No problem. Sometimes bad things happen. We’ve all been there. Hope your day gets better.
","text":"thank u.i hope u have a good day","replyToPid":131295}
 楼主| 发表于 2019-6-26 01:55:22 来自手机 | 显示全部楼层
630372 发表于 2019-06-25 17:13:45 Take a few pics and share next time to help other newbies
","text":"i will if it happens again.im still greasey from it","replyToPid":131288}
GMT+8, 2026-2-11 17:28 , Processed in 0.065718 second(s), 24 queries .
