{"replyTo":"","text":"I had a 2012 Volvo where my bunk went out like that. Took it to a dealer and it was the blower that went. Common issue they said","replyToPid":0}
{"replyTo":"","text":"most likely a fuse. if not try jumping it direct if that don't work motor is shot. if that work's you can run a inline fuse and toggle switch. not the best but at least you'll have a.c.","replyToPid":0}
607385 发表于 2019-06-25 16:27:38 I have a freightliner I reset the knobs, by holding down the return air ac and bunk button for 15 seconds.. idk if that will help as you are in a Volvo but best of luck.. try Google
629043 发表于 2019-06-25 15:38:16 most likely a fuse. if not try jumping it direct if that don't work motor is shot. if that work's you can run a inline fuse and toggle switch. not the best but at least you'll have a.c.
625878 发表于 2019-06-25 15:11:55 Yea buy a different truck?\nHahahahaha \n\nOn serious note. \nCheck the fuse that is under the dash. It usually is a relay that is too weak to function.
