查看: 306|回复: 33
Can somebody really quit smoking?
 楼主| 发表于 2019-6-24 06:37:15 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have friends who have tried but after a year or so, they will still go back to it. If you have ended smoking, how did you do it?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-24 13:32:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"5 years off cigarettes using vaping as my crutch. no where even close to being the same as smoking. no more symptoms of sleep apnea, food tastes better, I can smell far better too."}
回复 支持 4 反对 2
发表于 2019-6-24 10:50:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I quit almost 16 years ago and have not looked back - the key is I ran out of excuses to smoke so with that I set up a plan (change routines, things to take my mind off the function etc) then bought the patch and viola, absolutely the best decision I could have made - ps I smoked 1 1/2 to 2 packs a day for 20 + years","replyToPid":0}
回复 支持 4 反对 2
发表于 2019-6-24 19:04:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"sunflower seeds","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-6-24 12:45:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keep your mind busy elsewhere. You are not your body you trained to beg for stimulates. Get in front, not behind, and dragged your body along. ","replyToPid":0}
回复 支持 3 反对 2
发表于 2019-6-24 11:31:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"The amount of money smoking costs people is really why I never tried. ","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-6-25 02:03:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"i used vaping weaned myself off of nicotine and then quit vaping when my daughter wanted to try it been 4 years now with nothing","replyToPid":0}
发表于 2019-6-24 12:56:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes for sure","replyToPid":0}
发表于 2019-6-24 12:33:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"my dad quit cold turkey, but he's an alcoholic now 🤪. everybody needs a vice","replyToPid":0}
发表于 2019-6-24 12:12:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"My other half now uses nicotine pouches called Zyn. He loves it and can use it anywhere without anyone knowing.","replyToPid":0}
发表于 2019-6-24 10:45:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"most people don't quit they just start vaping. To me its pretty much the same.","replyToPid":0}
GMT+8, 2026-2-4 15:02 , Processed in 0.102700 second(s), 24 queries .
