查看: 412|回复: 13
Tips
 楼主| 发表于 2019-5-13 03:32:31 来自手机 | 显示全部楼层 |阅读模式
{"text":"How do i plan where to take my 10 hr break?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-13 09:09:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"No don't leave 2 hrs to find a parking spot. Wake up before everyone else and run your clock down to 10 minutes and have a guaranteed parking spot around 10:00-12:00.","replyToPid":0}
回复 支持 5 反对 1
发表于 2019-5-13 07:46:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"The same way u plan where ur gonna get fuel or where ur gonna get food or where ur gonna take a dump. Not that hard driver ","replyToPid":0}
回复 支持 0 反对 4
发表于 2019-5-13 09:28:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Early morning start time (if possible) Stay away from large truck stops, there is usually more parking available at the Mom and pop stops (drivers tend to frequent them less) . Most Walmart’s make a great place to take 10hrs. Use this app and your gps to judge your time, and you can run your clock down to almost zero everyday. Don’t stop very often and run hard through your 11 and you can make money. Stop every two or three hours and bullshit with these knuckleheads running around out here, and you’ll waste time, money and brain cells. Good luck driver, stay safe! ","replyToPid":0}
发表于 2019-5-13 09:28:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Early morning start time (if possible). Stay away from large truck stops, there is usually more parking available at the Mom and pop stops (drivers tend to frequent them less) . Most Walmart’s make a great place to take 10hrs. Use this app to find stops and your gps to judge your time, and you can run your clock down to almost zero everyday. Don’t stop very often and run hard through your 11 and you can make money. Stop every two or three hours and chat with all these knuckleheads running around out here, and you’ll waste time, money and brain cells. Good luck driver, stay safe! "}
发表于 2019-5-13 07:25:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Go out for a bit have dinner on an actual table next to real people lol\nI do that at least once a week ","replyToPid":0}
发表于 2019-5-13 11:19:11 来自手机 | 显示全部楼层
646611 发表于 2019-05-13 01:28:51 Early morning start time (if possible). Stay away from large truck stops, there is usually more parking available at the Mom and pop stops (drivers tend to frequent them less) . Most Walmart’s make a great place to take 10hrs. Use this app to find stops and your gps to judge your time, and you can run your clock down to almost zero everyday. Don’t stop very often and run hard through your 11 and you can make money. Stop every two or three hours and chat with all these knuckleheads running around out here, and you’ll waste time, money and brain cells. Good luck driver, stay safe!
","text":"best way to run. it's what I do when I can. I plan truck stop to truck stop to ensure I have amenities. company wants us in truck stops for safety.","replyToPid":33184}
发表于 2019-5-13 10:42:32 来自手机 | 显示全部楼层
","text":"U's chatting in return.\nIs U a nucklehead?","replyToPid":33184}
发表于 2019-5-13 09:25:56 来自手机 | 显示全部楼层
665824 发表于 2019-05-13 01:09:00 No don't leave 2 hrs to find a parking spot. Wake up before everyone else and run your clock down to 10 minutes and have a guaranteed parking spot around 10:00-12:00.
","text":"Guess U've neva been 2 NJ.","replyToPid":33176}
发表于 2019-5-13 09:04:35 来自手机 | 显示全部楼层
654793 发表于 2019-05-12 23:46:42 The same way u plan where ur gonna get fuel or where ur gonna get food or where ur gonna take a dump. Not that hard driver
","text":"Learn sum mannas \nboi","replyToPid":33115}
发表于 2020-11-22 01:47:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"you should understand that if enough people do this, your plan gets ruined and lots start filling up by 11. in just a year, we've had it happen with a shift from full by 7 to full by 6.\n\nthat's also an unnatural and unhealthy sleep schedule for most","replyToPid":0}
发表于 2019-5-13 09:05:02 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Truckstop or rest area \n\nB4 16:00\n\nGive yoself @ least 2 hours of clock left."}
发表于 2019-5-13 10:15:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"You just dont! Pedal to floor logs out the window. Keep the wheels rolling so you’ll be balling! ☝🏽","replyToPid":0}
GMT+8, 2026-4-16 12:25 , Processed in 0.146323 second(s), 24 queries .
