查看: 170|回复: 3
Worse Navigation
 楼主| 发表于 2019-6-21 17:38:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"Worse navigation ever. Never takes you on the interstates. ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-21 19:59:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"does the GPS have where you can set it so it'll send you on interstate. if so you may want to see if you have it set for the Highway.","replyToPid":0}
 楼主| 发表于 2019-6-22 19:48:27 来自手机 | 显示全部楼层
558104 发表于 2019-06-21 12:12:24 Go to your avoidance settings. You probably have highways checked. Uncheck that box.
","text":"I don’t even see a settings option ","replyToPid":127037}
发表于 2019-6-21 18:48:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah I feel ya. I use a map","replyToPid":0}
GMT+8, 2026-4-18 12:46 , Processed in 0.087753 second(s), 24 queries .
