查看: 202|回复: 4
If you have the power….
 楼主| 发表于 2019-5-13 00:56:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"What HOS mandate are you going to change and why?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-5-13 18:38:00 来自手机 | 显示全部楼层
681434 发表于 2019-05-13 10:36:36 Make the 30 (if we must have it...personally I’d eliminate it altogether) into up to 3 breaks of no less than 10 each, so bathroom and coffee stops count as a break.  Why sit around for a full 30 when a pit stop can break up the day?\n\nEliminate 14.  Make split break 6/4.
","text":"Or better still split could be 6/2/2 minimum.  More flexibility for rush hour.","replyToPid":33330}
发表于 2019-5-13 18:36:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Make the 30 (if we must have it...personally I’d eliminate it altogether) into up to 3 breaks of no less than 10 each, so bathroom and coffee stops count as a break.  Why sit around for a full 30 when a pit stop can break up the day?\n\nEliminate 14.  Make split break 6/4.","replyToPid":0}
发表于 2019-5-13 21:27:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Add four 30 min breaks for every 8 hours of works.. add 10 more ours off duty..lower da 14 hour day to 10.. we truck drivers need to take a break we too tired ","replyToPid":0}
发表于 2019-5-13 09:25:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Bump up line 3 limitation by 1 extra hour to 12.\nPush back the dirtay 30 for everay 12, not 8  hours.","replyToPid":0}
GMT+8, 2026-4-18 01:04 , Processed in 0.068658 second(s), 24 queries .
