查看: 264|回复: 8
Any advice for truck repair service On 96 KS
 楼主| 发表于 2019-6-20 03:46:16 来自手机 | 显示全部楼层 |阅读模式
{"text":"My truck keep shutting off \nI hardly can start my truck and after I can drive less than 3 mile After standing for couple minutes I can run again \nEngine keeps shutting down \nSomething with filters I think or .... \nAny suggestions what else I can do at least to move to Loves \n \nStuck on I 96 between Wichita & Hutchinson KS\nI hope to reach Loves ","videos":"[]","link":"{}","pics":"[]","canComment":true}
 楼主| 发表于 2019-6-22 02:01:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Summit Truck Group\n5549 Chuzy Dr, Wichita, KS 67219\n(316) 262-8413\nhttps://goo.gl/maps/XjfJCd85tKazahKQ6\nThank you for good service ","replyToPid":0}
发表于 2019-6-20 06:05:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you checked the coolant level?","replyToPid":0}
发表于 2019-6-20 06:42:14 来自手机 | 显示全部楼层
672031 发表于 2019-06-19 22:05:54 Have you checked the coolant level?
","text":"agreed. your tuck might be trying to protect itself from over heating. check your coolant temp and coolant level. if you have enough water, try filling up the coolant reservoir with it, just to get you to loves.","replyToPid":125588}
发表于 2019-6-20 07:04:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"Check park regen needed thingy or fuse on battery.","replyToPid":0}
发表于 2019-6-20 09:25:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"Need more info. What make/model/year? ","replyToPid":0}
 楼主| 发表于 2019-6-20 12:19:46 来自手机 | 显示全部楼层
","text":"Yes thank you","replyToPid":125588}
 楼主| 发表于 2019-6-20 12:20:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Got towing to the truck dealer shop in Wichita KS","replyToPid":0}
 楼主| 发表于 2019-6-22 02:06:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you dislike tell me why? Want to know more ","replyToPid":0}
GMT+8, 2026-4-16 23:03 , Processed in 0.107643 second(s), 24 queries .
