查看: 645|回复: 31
Manual or Automatic Transmission.
 楼主| 发表于 2019-6-20 03:02:39 来自手机 | 显示全部楼层 |阅读模式
{"text":"Which do you prefer?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-20 06:23:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Manual until they solve the problem of being stuck on ice. You can rock your truck back and forth to get it rolling on ice. Automatic you can’t as you need to come to a complete stop to change gears to and from reverse. ","replyToPid":0}
发表于 2019-6-20 08:23:25 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Auto . They’re starting to slow down on making manuals. Then electric trucks won’t have transmissions"}
发表于 2019-6-20 06:24:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Manual ","replyToPid":0}
发表于 2019-6-20 08:41:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I won't drive an automatic or electric. wat too many years before that happens. I'll be dead by then","replyToPid":0}
发表于 2019-6-20 09:44:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Manual, but not for the usual reasons. We have to back into some pretty tight places, and I'm used to easing on and off the clutch to slowly back in. The one automatic I've driven, the Volvo I shift, was nearly impossible to finesse into a tight spot without banging into the dock. I hear that some of the trucks have a \"creep\" mode for situations like this, but not this truck. I'm back in my 10 speed now.","replyToPid":0}
发表于 2019-6-20 08:50:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"I prefer a manual but recently got put into automatic they both have their pro's and con's but yes I miss my 10 speed.","replyToPid":0}
发表于 2019-6-20 08:21:56 来自手机 | 显示全部楼层
542330 发表于 2019-06-19 22:23:50 Manual until they solve the problem of being stuck on ice. You can rock your truck back and forth to get it rolling on ice. Automatic you can’t as you need to come to a complete stop to change gears to and from reverse.
","text":"R-N-R repeat ","replyToPid":125593}
发表于 2019-6-20 06:25:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"manual. better control coming down mountian passes and on ice.","replyToPid":0}
 楼主| 发表于 2019-6-24 04:44:07 来自手机 | 显示全部楼层
682867 发表于 2019-06-20 22:52:09 😂🤣😂....” any monkey can drive job”.... NAILED IT, NAILED IT, F’N NAILED IT.... now, if the could only back they could quit parking at the fuel island
","text":"Then it would be nicer","replyToPid":126506}
发表于 2019-6-21 06:52:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂🤣😂....” any monkey can drive job”.... NAILED IT, NAILED IT, F’N NAILED IT.... now, if the could only back they could quit parking at the fuel island","replyToPid":0}
发表于 2019-6-20 06:32:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I drive an automatic and it *****. No take off power.  No climbing power.  I prefer the manual.  In inclement weather it’s best for control. ","replyToPid":0}
发表于 2019-6-20 09:12:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"Millennial ...I mean... Manuel ","replyToPid":0}
GMT+8, 2026-4-17 18:39 , Processed in 0.120798 second(s), 24 queries .
