查看: 511|回复: 23
Weight rules
 楼主| 发表于 2019-6-19 08:44:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"So from what I understand there are two rules for the weigh stations..\n\n1.  gross weight can not be over 80,000\n2.  drive and tandem axles can not be over 32,000\n\nI got weighed at a shipper today after they loaded me and both axles were 500ish lbs over and they said it was legal.  it's ok to be a little over?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-19 22:11:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you don’t know this you should ride a bicycle! ","replyToPid":0}
回复 支持 2 反对 2
发表于 2019-6-20 05:51:42 来自手机 | 显示全部楼层
170943 发表于 2019-06-19 15:48:22 it's 12 k pounds, the steering wheel tires support only 6000 pounds each ones. At least mine do
","text":"we are talking the law here, not the budget tires your company puts on your truck.","replyToPid":125188}
 楼主| 发表于 2019-6-19 22:11:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"ok thanks guys.  I thought it was 32k on axles, good to know it's 34k","replyToPid":0}
发表于 2019-6-19 20:14:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"All good advice, I would add when I doubt go to the nearest CAT scale and weigh it. I never trust any shipper's scale, Also if your dispatcher tells you to get an empty scale ticket before you get to the shipper, Fill your fuel tanks, Then scale it. Most times it's Because the shipper is going to load you to the max weight.","replyToPid":0}
发表于 2019-6-19 23:48:22 来自手机 | 显示全部楼层
610123 发表于 2019-06-19 11:48:18 you are allowed 20000 on steers but people think it's just 12k because it is the balance of 80k if both sets of tandems are maxed
","text":"it's 12 k pounds, the steering wheel tires support only 6000 pounds each ones. At least mine do","replyToPid":124954}
发表于 2019-6-19 19:48:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"you are allowed 20000 on steers but people think it's just 12k because it is the balance of 80k if both sets of tandems are maxed","replyToPid":0}
发表于 2019-6-19 22:28:15 来自手机 | 显示全部楼层
{"replyToPid":124954,"replyTo":"
","text":"You’re exactly right. I’ve looked it up after my dad told me that. You’re allowed more than 12 on the steers. It’s the 80 total. But you can have more  on your steers than 12"}
发表于 2019-6-19 19:50:01 来自手机 | 显示全部楼层
625878 发表于 2019-06-19 00:50:06 Okay here are the weights for every state.\n\n12,000 for steering \n34,000 for drives\n34,000 for tandems on trailer \n\nTotal weight = 80,000 pounds.\n\nAlmost every state will allow you to be over on your steers, if you under the 80,000 pound gross weight.\n
","text":"1. Don’t rely on site scales!! \nScale at a certified weigh scale. The shipper will tell any rookie driver anything so know before you go. So, ASK ASK ASK another driver that is willing to give you some advise. \n2.  Roll into that scale at the posted speed and by all means don’t be on your phone\n3. Roll down the window to listen for loud speaker prompts\n4. Disengage your engine brake(jake brake) so you’re not jerking across the scale\nGenerally don’t be that drivernon the side of the highway just before a scale. Get your stuff together as soon as you’re done loading or at the Cat Scale","replyToPid":124629}
发表于 2019-6-20 09:47:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"BTW, for all you goons out here, stop giving advice for things you don’t know. ","replyToPid":0}
发表于 2019-6-20 09:39:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you don’t know the answer to your own question, that is a disgrace. It is pitiful that people so unqualified such as yourself are out on your own. I’m also sorry to say that almost all of the replies you have received are WRONG!!!  The front section of the Rand McNally Motor Carrier Atlas has all of the information you need. I have made a YouTube video on this but the new generation is so uneducated and unwilling to learn that my attempts have gone unnoticed. Ie: Florida allows 44,000 on a tandem. SC allows 35,500 on a tandem. Come on people, get with the program and be professional!!  Would you really take a ticket from DOT without actually knowing the regulations!!!","replyToPid":0}
发表于 2019-6-19 22:27:40 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"."}
GMT+8, 2026-4-18 07:01 , Processed in 0.097056 second(s), 24 queries .
